Gentlemen,
I hope someone can help.
The upper “rail” of the soft top that carries the weather strips directly above the windows needs to straighten entirely in order for the window to seal properly against the seal. Mine does not and I seek help to understand how this might be corrected. The photos are not the best quality, but I hope they explain the problem.
As the soft top is expanded out, the two sections that make up the top rails directly above the window should lock into a perfectly straight line. The left hand side is fine, but the drivers side (RHD) forms a slight “V” shape, that is lower in the centre. As a result the window glass cannot seal properly.
I am about to replace all the weather seals so want to correct this before installing. Mine never “locks” properly and if I push upwards against the centre there is definite movement that should not be there.
Does anyone know how I might be able to adjust this so it acts as a proper elbow that locks straight?
Jeff
