Author Topic: small switch under the dash  (Read 5635 times)
pj
  • Canada, ON, London, Ontario
  • 1965 230SL
    • my home page
« on: April 28, 2013, 09:38:14 »
There's a small red switch hanging under the dashboard of my car. I can't figure out what it's for. Is it on the wiring diagram, and I'm just not recognizing it? Is it an obvious non-original addition? Any ideas?
I haven't tried to follow the wires in detail. It's mighty congested up there and I don't know how you guys get your hands and eyes in behind the dashboard.
Peter J
1965 230SL #09474 named Dagny
2025 GLC300 coupe named Rigel
Re: small switch under the dash
« Reply #1 on: April 28, 2013, 09:40:33 »
That does not look original... so you'll have to trace the wires... because the switch is so small, it cannot be a high current item (like driving lamps) unless it is driving a relay (check under the hood if you have a non-original relay somewhere). Could it be from an alarm system or immobilizer?
Larry & Norma
« Reply #2 on: April 28, 2013, 10:02:37 »
I have seen a similar switch which turned out to operate the power antenna so if
using an ipod you can lower the antenna. I understand that front fender mounted
antennas create a lot of wind noise which can be annoying when the roof is down.
Obviously not a standard fit.
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
w113dude
« Reply #3 on: April 28, 2013, 11:44:41 »
might be a kill switch added and connected to electricals in the car.
Iconic
  • USA, IL, Highland Park
  • ex-Membership Administrator
« Reply #4 on: April 30, 2013, 17:28:15 »
How about a cold start device to turn the cold start valve on?
Is it a momentary switch that springs back after you release it or does it toggle and stay where you moved it to?
1998 BMW M-Rdstr Estoril Blue
pj
  • 1965 230SL
    • my home page
« Reply #5 on: May 01, 2013, 07:29:40 »
It's a toggle. I haven't done a thorough check of whether the behaviour of other systems depends on which position this switch is in. It's on my list of things to do.
Peter J
