Author Topic: Windscreen Washing Tubing  (Read 9721 times)
RBYCC
« on: April 29, 2013, 11:39:35 »
Can anyone post pix of the routing of the windscreen washer tubing from the bottle to the firewall and to the nozzle.
When I purchased the car it was without bottle and tubing.
I mounted the bottle next to the brake booster and temporarily routed the tubing to the cowl nozzle through the large plug on the top of the cowl.
It looks like it may route to a rubber grommet on the flat side of the firewall.
Any ideas how to fish the tubing from the nozzle to the proper firewall entry point ?
Thanks !
Ed A.
« Last Edit: May 01, 2013, 00:03:07 by 280SL71 »
Tomnistuff
  • Canada, Qc, Levis
Re: WINDSCREEN WASHING TUBING
« Reply #1 on: April 29, 2013, 15:00:34 »
Hi Ed A.
Here are three photos that I took to help me put mine back together when the restoration progresses that far.  The first is from the reservoir through the correct (I think) grommet in the firewall.  The second is the routing through the cowl air inlet chamber.  The third is the location of the hose hole into the cowl air inlet chamber.  You cannot see it from the pedal area inside the car but you can feel it in the hidden wall of the air inlet chamber where the red arrow points.  It`s the lower hole in the second photo.  The routing above the upper hole in the air inlet chamber is through the cowl scoop to the nozzle.  I think there are one or two clips to retain the hose in that area, but I don`t have a photo.
Good Luck!
Tom Kizer
RBYCC
« Reply #2 on: April 29, 2013, 17:49:15 »
Fantastic....much thanks... ;D
« Reply #3 on: April 29, 2013, 21:51:30 »
Ed,
Note the washer motor in the right position ;)
And, a wrongly painted solenoid ;D.
And wrongly painted Washer motor bracket ;D
And??
RBYCC
« Reply #4 on: April 30, 2013, 10:28:45 »
Gary
Much thanks  ;D
I have a 1971 280SL and I believe the correct location of the reservoir on the late model cars is next to the washer motor and in between the vacuum booster and the relays ?  ???
Ed A.
« Reply #5 on: April 30, 2013, 23:33:13 »
I believe that is correct.  On the earlier cars there was a bracket and on the later cars it was just tucked in there.  Just remember mine is a RHD. Here is a photo of 49'ers US engine bay?
Re: Windscreen Washing Tubing
« Reply #6 on: October 08, 2014, 19:06:57 »
What a night mare!
RobSirg
« Reply #7 on: October 09, 2014, 00:10:25 »
Guys, I notice the new washer motor you buy from SLS and others has a different sized bracket ( without the texture finish) that doesn't fit in to the holes in the engine bay ( you can screw one in and drill another which I don't wish to do). Does anyone know if you can purchase a new correct motor and bracket or do I need to try find a second hand one to refurbish?
Rob
1962 E Type Jag BRG with Tan
1974 White Alfa Spider 2000
2023 Range Rover
1982 280TE (my daily)
1977 Yellow 911 Targa
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
mbzse
« Reply #8 on: October 09, 2014, 09:28:57 »
Quote from: RobSirg
.../... new washer motor you buy from SLS and others has a different sized bracket ( without the texture finish).../...
I solve this by transferring the original bracket over to the new type washer pump. There are four little screws that hold the bracket.
Some good pictures in reply 1158 and 59 of this posting http://www.sl113.org/forums/index.php?topic=18284.25
/Hans in Sweden
/Hans S
RobSirg
« Reply #9 on: October 10, 2014, 04:09:54 »
Thanks Hans, I would l do that if I could but in this project car - it has already been replaced with the modern unit. Seems I need to find and old unit in any condition so I can use the bracket. At least it is good to know I can interchange the brackets. If anyone knows if you can still buy the correct one - let me know.
Cheers
Rob
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
« Reply #10 on: November 12, 2014, 22:43:20 »
Code: [Select]
Cheers
Rob,
The separate bracket - no.
The correct washer pump including the right bracket - yes.
A108 869 0121 - currently €€ 61.88 in Europe
A.
