Please check out joining the
Emergency Contact List
for help during your travels!
Electrical and Instruments
Oil gauge going up and down
Topic: Oil gauge going up and down (Read 4350 times)
akessel56
April 29, 2013, 23:58:06 »
Okay so what does it mean when your oil gage is at 45 then decides to go to 30, sits for a little and then goes to zero, sits for a bit and then goes back to 45?
Last Edit: May 04, 2013, 23:44:44 by 280SL71
Full Member
Platinum
USA, MD, Wheaton
Re: Oil gage going up and down
April 30, 2013, 00:37:34 »
Ouch.Dont drive the car anymore till you find out what is going on.
Could be the oil pump is bad.
Does the engine stumble a bit when the pressure fluctuates?
Maybe the distributor drive is bad as it operated the oil pump simultaneously.
Others will chime in with other suggestions.
Walter
akessel56
Reply #2 on:
April 30, 2013, 03:02:05 »
Driving fine, no sign of trouble.
Full Member
Platinum
USA, OH, Blacklick
Reply #3 on:
April 30, 2013, 05:01:35 »
Sounds like your low on oil. Have you checked the level?
akessel56
Reply #4 on:
May 04, 2013, 13:30:51 »
Low oil, I'm an idiot. Wouldn't think that would make the gage move while driving. But apparently all it was.
