Author Topic: Newbie with 280 SL transmission problem  (Read 4148 times)
coreyman97
« on: May 03, 2013, 15:59:10 »
Hi all -
Just joined today but I've owned my '69 280 SL for about 12 years. Recently I've been having problems with the transmission not holding when I put her in PARK. She'll roll a bit and there will be a clicking sound. Taking her to my mechanic next week, but figured I'd check and see if anyone else had this issue, or might help me diagnose the issue. I have always found forums to be the best source of help with nice, passionate people.
Corey
w113dude
Re: Newbie with 280 SL transmission problem
« Reply #1 on: May 03, 2013, 20:19:26 »
Most likely it's the transmission linkage that needs adjusting, may also need bushing or both.
coreyman97
« Reply #2 on: May 03, 2013, 20:28:18 »
Thanks for the quick response. Will have him look into the linkage and bushings.
« Reply #3 on: May 04, 2013, 02:21:46 »
Hello Corey,
As mentioned, the shift linkage rod has two replacable plastic bushings that fail due to deterioration with age. They are just a few dollars each. Have them  replaced now and save a tow bill later. The ratcheting noise is usually the result of the transmission not quite going into park because of the worn bushings. The shift rod can be removed by unfastening and  lifting the shifter assembly inside  the car and popping the linkage loose on the transmission.
ctaylor738
  • USA, VA, Falls Church
« Reply #4 on: May 04, 2013, 15:18:31 »
Suggest that they also check that the shift lever is not close to dragging on the plate that supports the transmission mount.  This happens with collapsed motor and transmission mounts.  No sense in replacing the bushings only to have the lever start hitting the plate.
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
coreyman97
« Reply #5 on: May 05, 2013, 10:19:03 »
Thanks everyone. I've printed out your advice so I can give it to my mechanic. He's very familiar with the car and I trust him completely, but I feel better knowing what the issue is, and what to tell him. Thanks again.
