Author Topic: Correct tire valve stems??  (Read 2822 times)
ctm14
« on: May 06, 2013, 03:24:23 »
  Getting ready to put new tires on the 280. I am going to go with the Vredestein's. I was wondering if anyone can advise on the correct original valve stems. I spoke with the classic center and they said they have the three sizes below. Does anyone know what the correct MB p/n would be for originality?
40 mm -  000-400- 02-13
48 mm - 000-400-03-13
62 mm - 000-400-04-13
ctm14
Re: Correct tire valve stems??
« Reply #1 on: June 17, 2013, 05:29:02 »
Any thoughts on the correct valve stem length?  ???
« Reply #2 on: June 17, 2013, 05:46:54 »
It depends on what wheels you have and if steel what trims you have.
The shorter ones are for alloy wheels.
