Author Topic: clunk when shifting into second gear  (Read 4695 times)
« on: July 16, 2004, 17:27:14 »
I recently bought a 1969 280SL 4 speed manual trans and I am IN LOVE with this car.......I have noticed a "clunk" when I am shifting into second gear although the transmission feels quite solid.....anyone ever experience this before?  Also what type of oil should I use (10-40?) the engine was rebuilt within the last 10K miles
Dan
Re: clunk when shifting into second gear
« Reply #1 on: July 16, 2004, 19:13:39 »
Your problem is worn synchro rings from gears 1->2. The synchros are designed to match the tranny shaft speeds (input/output) before the actual gears engage, this keeps things quiet. To repair this the transmission must be pulled apart and syncro ring(s) replaced. Not a small job, and might as well use a new clutch during re-installation.
Mike McMahon, Baltimore MD
1970 280SL 4-speed manual
olive green ext, bamboo int
erickmarciano
  • Canada, Quebec, montreal
« Reply #2 on: July 17, 2004, 09:08:52 »
what do the syncros cost?since I will be changing my clutch and reseal my trany is this a hard job ?one hour more???
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
graphic66
« Reply #3 on: July 17, 2004, 10:47:35 »
I think the standard transmission in a 113 used automatic transmission fluid
« Reply #4 on: July 17, 2004, 15:59:17 »
Mike...I think your right in reference to the synchro ring being the problems.....seem logical based on what is happening when I let the clutch out .......so here is the question.......anyone have a ballpark $$$ amount on how much it is going to cost to get the synchro rings repaired / replaced and a new clutch?  That ain't something I can do myself....
Dan
« Reply #5 on: July 17, 2004, 16:33:58 »
Dan call Pacific Motors and talk with Harry Hayashi. He is very knowledgeable when it comes to the W113. He's somewhere near San Francisco. 415-861-1013 This would be a great contact on the west coast.
erickmarciano
« Reply #6 on: July 18, 2004, 18:31:07 »
what do the syncros cost?since I will be changing my clutch and reseal my trany is this a hard job ?one or 2 hours more???
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
