Author Topic: Wiper motor linkage arms  (Read 4461 times)
anubis
  • USA, CA, Pleasanton
« on: May 22, 2013, 19:10:37 »
I need to replace the right side defroster vent in my 67 250SL (no a/c) and in order
to do this will need to remove the wiper linkage arm the vent is "wedged" behind.
I could not find anything in the Tech Section for removal - is it just a matter or prying
off the white plastic retainer ? I didn't see any circlips, and didn't want to use any force
before knowing how they actually separate.
Grateful for any help or direction...  thanks !
Bruce
Re: Wiper motor linkage arms
« Reply #1 on: May 26, 2013, 00:55:17 »
hi,
Can I suggest you look at the sls drawings of the wiper assembly to get an idea of the parts involved.
http://www.sls-hh-shop.de/en/230-280SL-W113/82-Lighting-and-Wiper/82-c-Windscreen-wipe-wash/
copy and paste
anubis
« Reply #2 on: May 27, 2013, 17:57:36 »
Thanks, Bob.
I learned (via Dave Gallon) that the way to undo the wiper arm linkage (under the dash) is with a battery terminal puller.
You can buy this tool at an auto parts store. Do not get the cheap version for $7-10, get the heavier version for $30.
It clamps onto the wiper arm, and you direct the threaded portion up against the seated ball. Turning the thread pops the ball out, separating the two arms. Take care to line things up correctly, as you cannot replace the plastic grommet if you break or damageg it ... you have to buy a new arm/assembly.
You want to buy the better quality puller as the head that pushes the ball out on the cheap version is quite poorly made and much larger in diameter - and will likely crack or break the plastic grommet.
