Author Topic: Overheating  (Read 3182 times)
bossanov
Overheating
« on: June 01, 2013, 23:09:03 »
Has anyone come up with a good fix for 280SL overheating problem? I have a new fan, recored oversize radiator, and new antifreeze and I am still heating up when I set at a traffic light.
w113dude
Re: Overheating
« Reply #1 on: June 01, 2013, 23:12:56 »
Take a look at this modification for 280sl cooling.
http://www.sl113.org/wiki/Cooling/RetrofitCooling
Re: Overheating
« Reply #2 on: June 02, 2013, 11:48:16 »
There are numerous discussions on this common issue; run a search and let us know what you find. Typical causes are restricted passages in the engine, trapped air in the system causing blockage, or a faulty thermostat. Main thing is that these cars can run normal, ie do not have to overheat and have this issue (which you are right in addressing due to the potential damage to the head).
ctaylor738
  • USA, VA, Falls Church
Re: Overheating
« Reply #3 on: June 02, 2013, 13:02:48 »
What do you call "heating up"?  How high does the gauge go?
What is your coolant mix?
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
Re: Overheating
« Reply #4 on: June 02, 2013, 17:24:31 »
I had a 230 recently that was o/heating. We had the radiator re-cored to no-effect. We had the radiator re-cored again with a larger tube core. No effect. We installed a second hand radiator from another car; problem solved. Go figure!
