Author Topic: Fuel injector cooling hoses needed. Where to buy?  (Read 3950 times)
ncsurfer
  • USA, NC, Raleigh
  • In good company!
    • Sandhills Motoring Festival, Pinehurst, NC
« on: June 03, 2013, 12:00:09 »
Hi Guys,
I am trying to find the 4 injector hoses in this pic. Does anyone know where I could buy them? Thanks....
1970 280sl Horizon blue/navy, automatic
1973 450sl Silver/red, automatic
1985 280sl red/beige, 5 speed
1995 E320 Cab. Black/Cream, Auto
2016 Porsche Boxster Spyder
2008 Porsche Boxster RS 60 Spyder
1964 MB L1113 Firetruck
w113dude
Re: Fuel injector cooling hoses needed. Where to buy?
« Reply #1 on: June 03, 2013, 16:22:47 »
your local Ace hardware or just about any auto-part store should have them, these are regular coolant hoses cut to size.
« Reply #2 on: June 03, 2013, 17:55:17 »
I'm afraid I can't tell from the picture exactly which hoses you're talking about.
ncsurfer
  • USA, NC, Raleigh
  • In good company!
« Reply #3 on: June 03, 2013, 19:03:01 »
Sorry....... There are 2 hoses coming off the left side of the injector thermostat housing and one off the right lower side of the injector body. The 4th hose is a cooling that comes from the heater core at the fire wall on the driver's side. It goes down 45* the turns and goes to the block. This is a formed hose.
Thanks.....
dasvinger
  • USA, NC, Durham
« Reply #4 on: June 05, 2013, 02:11:24 »
Steve,
Check with local NAPA, or CarQuest...most stock preformed heater hoses that should match. Found mine @ CarQuest.
Fred
'67 250SL White/Blue/Bamboo int
« Reply #5 on: June 05, 2013, 03:02:27 »
The two hoses to the left of the thermostat are cooling water hoses, and are just standard size hoses cut to fit (but the hose by the meter from the local MB dealer). The bottom hose is not cooling water, but air inlet. There has been some mention on the site about this special hose marking (which is not available) I think it is the same size as the heater hose. The fourth one is going to the head (from the heater) and depending on the car, may or may not be a special "formed"hose. On my 250 SL it is just a piece of hose cut to fit.
