Author Topic: Points  (Read 6648 times)
badali
  • USA, Pa, Butler
  • 1966 230SL
Points
« on: June 06, 2013, 19:34:09 »
I noticed at the end of summer last year my car was harder to start and would stall occasionally at idle.  Yesterday I put in a new set of points and now the car fires up instantly and runs great again.  I have put about 6000 miles on the car since I bought it and this was the first problem I had with the run ability of the car.  A simple fix for under $20.  What is the typical life of the points in our cars?
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
2025 E53 AMG Sedan
Re: Points
« Reply #1 on: June 06, 2013, 23:46:16 »
Hey. As some of you know, I had a few cold and warm starting issues over the years -- usually remedied at least for a while by new points and plugs. (I can hear the chant of 1-2-3- 1-2-3 ...)
But then I finally chased down a cold start problem to a faulty TTS. Once I replaced that feller, I have had incredibly normal, consistent starts and long-lasting points. I would say I am at about 10,000 miles (about 4-5 years?). I can check. And if I didn't just jinx them, they are still fine. This is one reason I remain a purist -- sticking with points.
kampala
  • USA, CA, Beach Cities
Re: Points
« Reply #2 on: June 15, 2013, 16:10:52 »
What is TTS?  Have tried to search and can't find what this acronym means.
I have points and it seems the car starts instantly cold or warm about 70% of the time.  The other times it needs to crank about 5 - 8 seconds.  I generally allow the fuel pump a 5 second head start.   TTS?
250sl - later - manual
280sl - 1971 - Auto - LSD
Re: Points
« Reply #3 on: June 15, 2013, 17:49:18 »
280SE Guy
  • USA, PA, Birdsboro
    • some pics
Re: Points
« Reply #4 on: June 15, 2013, 18:36:29 »
Back in the day if you had a 1960 - 1970 car you would change the points, cap, rotor, and spark pugs twice a year. First before the winter (as in Wisconsin or Minnesota) were it gets really cold, and then in the spring. Of course you were driving the car every day. I have been recently searching for some spare points, rotor and cap for my M130 W108 and was at the dealer this last Thursday and got a quote of (with MBCA discount):
Cap        $57.20
Rotor      $27.20
Points     $17.00
A far fetch from my order back in April of 1985 as seen on the attached image
280SE Guy
kampala
Re: Points
« Reply #5 on: June 16, 2013, 05:18:01 »
Appreciated.  Thanks.
Re: Points
« Reply #6 on: June 19, 2013, 19:52:28 »
Cap        $57.20
Rotor      $27.20
Points     $17.00
As an FYI, these are all, as you know, Bosch parts except the filter.  Typical pricing for these Bosch parts today, (not at a dealer of course) is as follows:
Cap: $14-$20 (depends on cast iron/aluminum distributor)
Rotor $7-$11 (again, see above)
Points $6-$7 (depends...)
Oil Filter (Mann OEM) $4
So, worst case today, for OEM Bosch parts for your 280SE, would be $42. That's not that bad after all these years!
280SE Guy
    • some pics
Re: Points
« Reply #7 on: June 19, 2013, 20:24:37 »
Thanks Michael,
I have been meaning to get to a local parts center that handles Bosch parts to see what their price is. I'll bring your pricing along as a guide.
I was just thinking that I needed to add to my inventory of parts, maybe 2 or 3 sets of the tune up items for future use.
I have an ample supply of oil filters.
280SE Guy
Re: Points
« Reply #8 on: June 20, 2013, 11:22:34 »
Those particular prices were from AutohausAZ but I've found that for some of their parts, prices hover around the same...might be a bit more at a local foreign auto parts dealer, but worth checking out.
