Author Topic: Torque setting for 230SL steering wheel?  (Read 3352 times)
relbhcb
« on: June 08, 2013, 19:02:45 »
Does anyone know what the torque setting is for the single large nut that holds the steering wheel on to an early 230SL? Or where I would find it?
I had to remove my steering wheel to fit a new multi function "stalk" and would like to know how tight I need to do the wheel up again.
Many thanks!
Julian
PS I did search, but couldn't find anything ...
mbzse
Re: Torque setting for 230SL steering wheel?
« Reply #1 on: June 08, 2013, 19:28:04 »
Quote from: relbhcb
Does anyone know what the torque setting is for the single large nut that holds the steering wheel on to an early 230SL...
The M-B Book of Tables states it to be 80Nm
/Hans in Sweden
/Hans S
relbhcb
« Reply #2 on: June 09, 2013, 07:08:04 »
Hans - many thanks!
mbzse
« Reply #3 on: June 09, 2013, 08:19:39 »
The M-B Book of Tables states it to be 80Nm. You may want to use some light locking compound (like Loctite) to be extra sure.
/Hans in Sweden
/Hans S
« Reply #4 on: June 12, 2013, 23:00:45 »
There should be a lock under the nut to keep it from working loose. I won't use lock tight on anything I want to take apart some day. If anything, I use anti sieze more often than anything else.
Because the steering wheel is kind of hard to hold on to while tightening this nut, I use my impact gun to make sure it's tight. Put it on a low setting.
