Author Topic: inner door handle bezel  (Read 6052 times)
jmbour
  • France, Ile-de-France, Paris
« on: June 09, 2013, 12:20:29 »
I need some help to take off the inside door handle bezel, in order to remove the door panel and fix a window.
The technical manual says that it should "pop up" with the help of a thin screwdriver.
I don't want to break it, and would like to know exactly how to proceed.
JMB
1971 280SL US
1973 280CE
1987 300 E
2005 C230
KevinC
Re: inner door handle bezel
« Reply #1 on: June 10, 2013, 00:54:38 »
jmbour
« Reply #2 on: June 10, 2013, 08:44:58 »
Thanks, Kevin,
It helps, but partly because my SL is a late 280 with the square bezel (not the round showed on the pic)
Should I understand that the chrome bezel stays on the panel and I have only to take of the black plastic plate behind the lever ?
JMB
1971 280SL US
1973 280CE
1987 300 E
2005 C230
jmbour
« Reply #3 on: June 10, 2013, 13:24:20 »
O kay, I took the black plastic off and found behind it the screwn holding the bezel.
Everything after that was simple, but I had a bad surprise when I looked at the window mechanism.
JMB
1971 280SL US
1973 280CE
1987 300 E
2005 C230
KevinC
« Reply #4 on: June 10, 2013, 15:22:40 »
I hate bad surprises.
« Reply #5 on: June 10, 2013, 19:02:59 »
The only surprise to me is that you were surprised!
jmbour
« Reply #6 on: June 11, 2013, 09:23:12 »
The bad surprise is that he window regulator arm is broken.
And, of course, you cannot find a new arm, you have to replace the entire regulator, or find a repair kit (see my other post)
JMB
1971 280SL US
1973 280CE
1987 300 E
2005 C230
« Reply #7 on: June 12, 2013, 06:00:48 »
Why don't you have the arm welded?
jmbour
« Reply #8 on: June 12, 2013, 08:59:40 »
I appreciate your advice.
For the moment, I am looking for a used part or for a repair kit somewhere in Europe.
I only need the broken arm, not the whole regulator, which is very expensive to replace.
But it does not seem that there are some replacement arms on the market. Only Bud's is proposing a kit to reinforce it, but it has to be welded.
There are also some used regulators for sale on Ebay, but these parts are sold in the US, and the cost of shipping to France is prohibitive.
So, I am still looking around, and will get it welded if I don't find any other solution (it has to be welded very carefully to get it to its original shape).
JMB
1971 280SL US
1973 280CE
1987 300 E
2005 C230
jmbour
« Reply #9 on: June 21, 2013, 16:05:30 »
Thanks to ja17,
I had the arm welded, I ordered some spare parts to replace the guide jaws, and my window is now working perfectly.
The fix is the same as proposed by Bud's on Ebay, but was made locally. I think that the problem was caused by a missing jaw, and I am ready to bet that the arm will not break again  !
JMB
1971 280SL US
1973 280CE
1987 300 E
2005 C230
