Author Topic: Repaint gas tank and ATE brake booster  (Read 3182 times)
« on: June 24, 2013, 23:28:50 »
I am trying to cleaned things up for safe driving. I want to repaint my original Brake booster and gas tank.
Any suggestions as to what color black both these items should be painted?
Also I want a paint that will harden and not be affected by solvents. Should I go with a urethane paint that hardens quickly?
What is the acceptable gloss level for the brake booster and the gas tank?
At the same time that I drop the gas tank,  I will have it cleaned out and new filters put in.
Any suggestion would be appreciated.
1968 280SL
« Last Edit: June 25, 2013, 00:02:21 by 280SL71 »
Re: Repaint gas tank and ATE brake booster
« Reply #1 on: June 25, 2013, 13:42:32 »
My ATE booster was purchased new; it has a semi-gloss, bordering more on glossy, black paint.
The gas tank was also purchased new; it has a semi-matte, or satin "chassis black" finish that closely matches the chassis components which had been powder coated to "chassis black" in restoration.
Though both of these parts were not "original" to the car, they were both bought as new and delivered with those finishes.
dseretakis
« Reply #2 on: June 28, 2013, 12:16:49 »
How about POR-15 chassis black paint?
travellerdogs
  • Canada, British Columbia, Bowser
« Reply #3 on: June 29, 2013, 17:16:48 »
Hi Bob, I sanded mine down to bare metal, washed it with thinners and sprayed 4 coats of a black Rust paint. Turned out with a nice gloss finish and the gas doesn't affect it. Carey
travellerdogs 1969 280SL,  1981 380SL:  1955 HD Panhead: 2007 HD Street Glide: 1956 Mercury Montclair, Black 2 Dr Htp; 1965 230SL: 2005 Pontiac Sunfire: 1993 Range Rover: 1977 450SL parts car:
