Author Topic: repair or replace clutch slave cylinder  (Read 3774 times)
rutger kohler
« on: June 25, 2013, 01:49:02 »
Hi, whilst my clutch works perfectly, I have noticed a pesky drip from the rubber shroud on the front of the clutch slave cylinder, onto my painted garage floor.  As parts have to be sourced from either Germany or the USA, to NZ, the freight is extremly expensive.  My question is, has anyone repaired a clutch cylinder successfully or should I just replace the whole cylinder?  If no one has successfully repaired one it might be more cost effective to get a new cylinder rather than a repair kit?
Interestingly the slave clutch cylinder appears to be the older version, accodring to pictures in the Haynes repair manual, whilst the car is a 1969 280SL with 129,000 miles on the speedo.
1969 280 SL Manual gear shift
1972 280SE 3.5 auto
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
Re: repair or replace clutch slave cylinder
« Reply #1 on: June 25, 2013, 03:55:50 »
I have not repaired a 280sl Slave cylinder but have rebuilt ones in my old MGBs and BMWs and have seen everything from easy rebuild to garbage due to a rusted bore.  When I got my car one of the first things I got was a rebuild kit.  Then one day I asked at the parts counter about a new cylinder and it was so cheap I just bought one.    I am prepared to rebuild the old one first so I can see what actually fails and if that doesn't work replace with a new one.   I like having new replacement items on my shelf but really like rebuilding items where I can.
If your car is not as much of a toy to you as mine is to me, I would suggest getting a whole new cylinder but make sure that the one you get matches the one you have as there appear to be differences.
I think I paid about $35.00 for a rebuild kit and $75.00 for a new cylinder (he may have given me a deal-I can't remember).
I tried to rebuild my brakes as well and that didn't go so well - I bought all new ATEs instead.
Ian
69 280SL
65 F-100
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
08 NPS50
12 Pro 4X
w113dude
« Reply #2 on: June 25, 2013, 12:24:28 »
Buy a new one. not worth it.
georgem
« Reply #3 on: June 25, 2013, 12:25:06 »
The repair kit is really only a couple of rubber seals and a rubber boot, but you are wasting your time if you don`t do something with the cylinder bore. You can hone it or have it re sleeved with stainless - although still probably cheaper to get a new one, even with the Kiwi freight penalty. The benefit of repairing esp with re sleeving is that it will last forever and you know it will fit. Happy for you to send it to me for stainless re sleeving  as I have a cylinder recon company 10 min drive away.
George McDonald
Brisbane
230 Sl
1973 VW Kombi Single Cab Ute
rutger kohler
« Reply #4 on: June 27, 2013, 22:48:06 »
Guys,thanks for that, good advice.  I think I will get kit and look at hone or rebore  at this point.
cheers
Rutger K
1972 280SE 3.5 auto
