Author Topic: Tires Squeal in tight turns?  (Read 8767 times)
« on: July 19, 2004, 19:14:16 »
Sorry for all of the questions, but trying to get to know my new baby...
When I make sharp, slow turns, ie. in the parking garage, pulling into my garage, the tires squeal...
The car has Michelin MX4 195/75/R14 tires installed.  I currently have the front and rear air pressure set at 32psi.
Inside the trunk lid (original sticker in trunk), it states 26 front and 32 rear.
What is correct?  Should I follow the trunk reading?  This would mean lowering the current pressure in the front wheels.
I always thought that when tires squeal that it indicates that the pressure is too low?
Confused...  any advice is greatly appreciated!
Memphis, TN.
Automatic, Light Beige, Cognac
Re: Tires Squeal in tight turns?
« Reply #1 on: July 20, 2004, 06:16:05 »
Hi Bob,
The pressures quoted on your original boot sticker would be for the original size tyres of 185 HR 14 (80% profile)
Modern tyres with different treads and tyre wall/profile height and construction will require pressures stipulated by the tyre manufacturer.
Bob (Brisbane,Australia)
« Reply #2 on: July 20, 2004, 08:14:37 »
I run 28 psi in the fronts, car feels a bit more stable on the freeway with that pressure.  I don't think the low speed squeal necessarily indicates low pressure, every car/tire combo I've ever had squealed in low speed turns, especially on concrete surfaces.
« Reply #3 on: July 20, 2004, 08:43:24 »
I wouldn't worry too much about front tire squeal in parking garages at all.  Just about all cars do this.  The concrete floor in indoor spaces is generally finished to a smoother finish than outdoor concrete and does not weather and erode over time as it does outdoors.  The front tires do not both describe a perfect arc when at full lock so one tire will "scrub" a little, plus the the front tires may "push" a little on the smooth surface when you are turning, thus the squeal. If you think that your tire squeal is loud, you ought to hear what a turning car sounds like on a painted garage surface!
« Reply #4 on: July 20, 2004, 11:34:34 »
Thanks Mike, George, Hands_Aus (Bob).  All of your comments have helped!
Memphis, TN.
