Author Topic: muffler bumper  (Read 3422 times)
rmmchl
  • USA, WV, Charleston
muffler bumper
« on: July 19, 2013, 00:27:18 »
I have seen listed in our parts descriptions, a type of rubber shock absorber  that goes above the rear muffler. I think it is installed above the rear muffler hanger, but I'm not at all sure. I didn't put one of these on my 250SL years ago, when replacing the muffler system. Does anyone have a photo and/or description, that shows where this goes and how it is installed. Is it only for 250 SL's, or did the 280SL use them also?
« Last Edit: July 19, 2013, 00:42:42 by rmmchl »
michael romeo
1967  250sl
signal red
pj
  • Canada, ON, London, Ontario
  • 1965 230SL
    • my home page
Re: muffler bumper
« Reply #1 on: July 19, 2013, 05:59:07 »
Hi Michael,
check this thread: www.sl113.org/forums/index.php?topic=18857.0
Is that what you're talking about, or something else?
Peter J
1965 230SL #09474 named Dagny
2018 B250 4matic named Rigel
Re: muffler bumper
« Reply #2 on: July 19, 2013, 09:46:14 »
A small black rubber stand-off fits above the metal bumper in a hole in the cross piece that spans the pipes.
The "point" of the black bumper goes into the hole in the pipe spanner so that the piece pushes against the metal bumper.
This is to stop the pipes from hitting metal to metal when going over rough ground.
The pipes are held up by rubber rings which can shake and stretch a bit when disturbed.
Here are a couple of rubber bumpers for you to admire.
...and here is a link to my mention of this part awhile back.  Look at "Rear Exhaust Bumper".
Some other often missing parts are also mentioned in that post.
http://www.sl113.org/forums/index.php?topic=12065.0
Richard M, NYC
« Last Edit: July 19, 2013, 09:51:41 by 280SL71 »
rmmchl
Re: muffler bumper
« Reply #3 on: July 19, 2013, 17:29:59 »
thanks for the photos-but I would like to have better pictures that show where the bumpers actually are inserted
michael romeo
1967  250sl
signal red
49er
  • USA, CA, El Dorado Hills
Re: muffler bumper
« Reply #4 on: July 19, 2013, 17:57:32 »
Does this help? I have an aftermarket SS exhaust system so the bracket might not look exactly like the MB system.
John
1969 280SL 003820
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
Re: muffler bumper
« Reply #5 on: July 19, 2013, 18:02:38 »
Check out the post for  "Rear Muffler - sanity check"  The second to last photo shoss the pipes and a hole in the car above the pipes - that is where the bumper goes - it mates with the flat piece of metal bracket joining the two tail pipes.   If you follow the thread you will note that the flat piece of metal on the exhaust in question is installed incorrectly and the 2nd to last photo doesn't even have that flat piece of metal.
This is where stock systems have the fittings to mate with the car properly.
Ian
69 280SL
65 F-100
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
08 NPS50
12 Pro 4X
rmmchl
Re: muffler bumper
« Reply #6 on: July 20, 2013, 04:34:14 »
thank you-I understand it now. I see where it goes-nice job with the photo.
michael romeo
1967  250sl
signal red
