Author Topic: Injection pump oil level  (Read 4564 times)
thoan
« on: July 29, 2013, 03:33:36 »
Car is a 1965 230SL.  The injection pump has a red "Oel" cap over the filler.  The dipstick is missing from the inside of the cap.  How far below the hole should the oil be?  (And, where could I buy a cap with a dipstick?)
My first post here.
Thoan
kampala
  • USA, CA, Beach Cities
Re: Injection pump oil level
« Reply #1 on: July 29, 2013, 13:54:21 »
This thread below will help you find where the dipstick is located on the pump ... also you'll find more on this topic ....  try various combination of words in the "search" function.   Good luck.
http://www.sl113.org/forums/index.php?topic=4199.0
« Last Edit: July 29, 2013, 13:58:39 by kampala »
250sl - later - manual
280sl - 1971 - Auto - LSD
scoot
  • USA, CA, Altadena
« Reply #2 on: July 29, 2013, 15:36:39 »
My first post here.
Thoan
Welcome.   The dipstick is in a separate location from the red cap.  Feel around down there lower and you will find it.  It is a T-shaped handle that unscrews.
Scott Allen
'67 250 SL (early)
Altadena, California
thoan
« Reply #3 on: July 29, 2013, 18:27:35 »
Found it, hiding below the solenoid.  Thanks to all.
« Reply #4 on: July 30, 2013, 02:11:03 »
Good work.
 If the pump is over fillled or the oil is dirty you can suck it out using various methods discussed on this forum and then carefully refill it to the line on the dip stick. Over filling will affect how well the pump works so pay attention to the level when checking.
I look at mine about twice a season because I know it's working right. If you pull the dip stick out and oil pours out all over the place, either someone over filled it, or the seals are leaking fuel into the bottom of the pump. I would monitor the oil level frequently if I found an over fiull oil level until I was sure it was simply over filled and not leaking seals.
