Author Topic: maximum opening of the hood  (Read 2995 times)
Rodolfo
« on: July 30, 2013, 14:00:27 »
When I work on the engine, sometimes the hood is kind of annoyingly obstructing the view and access. I remember my 1996 E320 where I could move the hood fiurther open to vertical position. That was the easiest access ever to the motor compartment.
The hood on the my 230 sl is limited by a strap. If I would release that, would the hood open to vertical?
Maybe a silly question, but access would be much better for some works. I want to avoid of course damaging the hood.
thanks, Rudy
280sl1968
Re: maximum opening of the hood
« Reply #1 on: July 30, 2013, 14:37:25 »
It will open further, but if it goes too far, the tension rod/prop will slip out of the other side of the holder, spring back and potentially cause damage to paintwork, fingers etc.
David
scoot
  • USA, CA, Altadena
« Reply #2 on: July 31, 2013, 20:24:28 »
On my car if the hood opens further it will hit the condensor for the A/C in front of the radiator...
Scott Allen
'67 250 SL (early)
Altadena, California
garymand
  • USA, CA, Meadow Vista
« Reply #3 on: July 31, 2013, 21:20:01 »
Good question, but no.  It's not a feature in the W113, but the way the 113 hood is attached is about as light weight as they could think of at the time.
Gary
