Author Topic: Timing Marks  (Read 3186 times)
jszeman1
  • USA, NY, Waterford
Timing Marks
« on: August 03, 2013, 18:08:40 »
I have an early 63 230sl and the timing should be 4 degree BTC.  The markings on the damper are 1,2,3.  can anyone tell me what these numbers mean and where I should set timing for 4 degrees.
« Last Edit: August 03, 2013, 20:43:28 by jszeman1 »
JohnS
Re: Timing Marks
« Reply #1 on: August 04, 2013, 00:15:32 »
Normally "top dead center" is marked with a "0" and then "10", "20", "30" etc. up to about "60". Each of these marks have an unlabled markfor five degrees, half way between them.   I suspect that your "1,2,3" is your "10", "20" etc.
jszeman1
Re: Timing Marks
« Reply #2 on: August 11, 2013, 01:10:50 »
Thanks Joe,  You are correct and the timing is dead on.  John
JohnS
Re: Timing Marks
« Reply #3 on: August 11, 2013, 02:54:12 »
The very early VA distributor has more total advance than the later VR 051 which is 30 degrees. I think it's closer to 36 degrees so setting your timming at 4 degrees should be just about right. I'm running 40 degrees full advance on my car and it runs well at that amount.
