Author Topic: Power Steering Pump  (Read 4103 times)
rjgricius1
  • USA, FL, longboat key
Power Steering Pump
« on: August 19, 2013, 20:40:28 »
Does anyone know where I can get a power steering pump rebuilt for a 67 230 sl? Very loud sounds like a bad bearing. The Classic Center no longer sells the bearing kit, they only have replacement shaft and seal kit.
230 sl 1967 automatic
wht/blue  in the middle of comple restoration
garymand
Re: Power Steering Pump
« Reply #1 on: August 19, 2013, 22:37:24 »
Most bearing on these cars are standard bearings.  The pumps are comon too.  Its the same pump on my 90 560.  I am guessing the bearings are standard ball bearings like a 6203.  pull it apart and see what you have.  http://www.sl113.org/wiki/Steering/PowerSteeringBox
scoot
  • USA, CA, Altadena
« Reply #2 on: August 26, 2013, 17:01:31 »
I bought a rebuilt one from autohausaz for my 67 250S.  The only trick is having the pulley-puller tool to get the PS pulley off the pump which you have to do before removing the pump.
Scott Allen
'67 250 SL (early)
Altadena, California
