Become a
Full Member
Emergency Contact List
fuel injector pump oil overflow early 250sl red cap
Topic: fuel injector pump oil overflow early 250sl red cap (Read 3258 times)
merutka
August 20, 2013, 20:59:49 »
oil was leaking out my red cap. 1 liter per 200 miles. turned out to be 6 seals under the plungers. a pain to replace. access from top and side cover.
garymand
Inactive
Gold
USA, CA, Meadow Vista
Re: fuel injector pump oil overflow early 250sl red cap
August 21, 2013, 20:43:11 »
So gas was leaking past the seals. Then the oil was drained and refreshed?
Gary
Early 250SL German version owned since 71, C320, R350, 89 Porsche 944 Turbo S
merutka
Reply #2 on:
August 22, 2013, 19:41:31 »
no gas was leaking. it is stopped by the oil film seal between the plunger and piston case. The seals stop high pressure oil from pushing into the lower part of the pump.
garymand
Inactive
Gold
Reply #3 on:
August 23, 2013, 20:39:48 »
Thanks, that helps.
Gary
