Author Topic: Engine Alloy parts restoring help Needed  (Read 8304 times)
slowcar
« on: September 09, 2013, 08:28:23 »
Hi  i have just bought a RHD 280Sl and want to add some life to the valve cover,head and intake manifold.
Is there a spray on type product?
Also what is the correct finish to the wood work,Matt ,Gloss ?
John
Khurram Darugar
Re: Engine Alloy parts restoring help Needed
« Reply #1 on: September 09, 2013, 11:44:51 »
Get them bead blasted and coated with either clear powder coat or heat resistant clear coat.
Kay
« Reply #2 on: September 09, 2013, 12:33:23 »
Any kind of xxx-blasting of an aluminum or other soft-metal product such as the valve cover will result in a texture that you may not want because it was not there or isn't original.  Aluminum is easily cleaned and brightened chemically; do a search in your location for "aluminum cleaners" or "aluminum brighteners", or go to an industrial supply house and you'll find what you need.
Khurram Darugar
« Reply #3 on: September 11, 2013, 13:39:59 »
Michael,
I will bow to youre judgement on this.
With the following caveat.
I did not have much success with degreasers.
Bead blasting or something complilmentary to aluminum resulted in the correct finish in my case.  At least i think it is!   ???  Everything came out looking new and with a matt finish
Kay
garymand
  • USA, CA, Meadow Vista
« Reply #4 on: September 11, 2013, 18:13:46 »
$.02: The surface of the cover is very smooth but not polished.  Don't blast it as the texture will roughen the finish.  Typically it is just oxidized and lightly stained, blasting isn't needed.  Mine is just degreased and given a coat of WD40.  I don't like the polished shiny thing, that''s too far from original.  I like the patina.  The manifold cleans up perfectly with just degreaser.  I don't have a better protectant than just WD once in a while.  It even looks good on the injection lines.  Natural beauty of original surfaces.
If you degrease and don't coat with WD, everything shows the oxidation.  JMO...
Gary
280SE Guy
  • USA, PA, Birdsboro
    • some pics
« Reply #5 on: September 11, 2013, 20:38:07 »
I would think this is the finish you would be looking to achieve:
280SE Guy
Edit: This is the original untouched finish.
« Last Edit: September 13, 2013, 04:02:03 by 280SE Guy »
garymand
« Reply #6 on: September 11, 2013, 20:48:16 »
ahh, a fine example! even the tiewraps are accurate.
Gary
« Reply #7 on: September 11, 2013, 21:33:28 »
It depends entirely  on what material you use in the preening of the cover and manifolds to get it right. The material must be considerably softer that the casting material.
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
garymand
« Reply #8 on: September 11, 2013, 22:00:26 »
Yes, that's what I was getting at: You can see the roughness on the cover from it being blasted.  Its not smooth like it was stock.  BTW, There are a couple of clamps missing on the FI pipes.   :-*
Gary
drmb
  • New Zealand, Waikato, Te Awamutu
« Reply #9 on: September 11, 2013, 22:10:58 »
That roughness is nothing to do with the blasting,230sl's have rough cast covers not smooth like 280sl's.
Mercedes Restorer.
1969 280sl 050 whte Blue interior
1996 E320 Cabrio
1963 220se 111-023 cabrio, red,black interior.
1967 Morris Cooper
Lloydmarx@xtra.co.nz
« Reply #10 on: September 12, 2013, 02:37:26 »
A lot has to do with what kind of blaster you use, how much pressure, and how far away you keep the blaster nozzel from your work. Some aluminium pieces can't be cleaned with chemicals. You can remove grease and stuff like that in a mild caustic solution - too strong and it will make quick work of alloy metals. I give that sort of thing to my machine shop.
Stuff that gets a light sand blast can be pollished with a soft wire brush. Having your parts completely free of any grease or moisture is really important if you have to blast any parts because sand will stick to those wet or greasy areas. I always let things sit for a few weeks after blasting and then I try to shake any sand out of them with an air wand.  Very important around valve covers and cylinder heads. You may swear you have every spec of sand out of them and find a hand full two weeks later - then you just swear......  ::)
« Reply #11 on: September 12, 2013, 07:46:34 »
I actually have used Walnut shell and it works well on everything.
andyburns
« Reply #12 on: September 12, 2013, 19:06:54 »
There is massive variation in finish depending on the media used.  If you take your parts down to a local bead blaster they will likely have very coarse general purpose media which almost has a 'fluffing' effect on the alloy.  I have been using AD or AE stock which gives a really nice finish.  Another aspect which dictates results is the operator skill.  If you sit in one place hammering the surface you will get an uneven result as well.  The trick is to keep the media moving over the surface in even motions.  I have also tried other tricks like using a very very fine scotch pad to slightly linish the alloy after it comes out of the booth.  I think there are a number of way to get the same result.
1963 230sl
1967 250s w108
1969 BMW 2002
2007 Mitsubishi i car
slowcar
« Reply #13 on: September 14, 2013, 00:09:59 »
Thanks for all the input.
The second question is what is the correct finish for the dash wood? How to get it there?
« Reply #14 on: September 14, 2013, 09:10:30 »
I have my alloy parts vapour blasted.
The wood can be anything you want it to be unless you want it to be original, in which case it will be what is commonly referred to as light or dark oak (although I don't think either are actually oak!) They were the only two choices.
I offer my customers a much wider choice and walnut in high gloss is a popular choice.
280SE Guy
    • some pics
« Reply #15 on: September 14, 2013, 10:48:28 »
Here are a couple of pics of an original finish on W108. I believe this is the walnut wood although there was a couple of different woods used depending on the optional wood selected at time of the order.
Please tell us what model do you have?
280SE Guy
« Reply #16 on: September 14, 2013, 13:14:13 »
Quote
From the OP:
Quote
wharlan
« Reply #17 on: September 17, 2013, 03:30:01 »
I was in the same bay recently and used P21 metal polishing soap with very good results.  It restores the finish to a clean but not over restored look inexpensively and with little risk.  It is available from car care online: http://store.carcareonline.com/p21smetalpolishingsoap-106ozjar.aspx
Hope this helps
Will
