Author Topic: Engine and Under Carriage Cleaning  (Read 2484 times)
« on: July 25, 2004, 07:54:08 »
I am considering taking my 280 SL down to my local carwash to have the engine and under carriage cleaned.....they have cleaned the engine on my Tahoe in the past and done a fine job.....of course I am concerned about having them clean the SL.....anyone have any tips or recommendations for this procedure?
Dan
  • USA, VA, Alexandria
Re: Engine and Under Carriage Cleaning
« Reply #1 on: July 25, 2004, 08:18:54 »
Couple of thoughts:
Be there with them when they clean and ensure that all electrical components (relays, distributor, alternator) are covered with plastic.  I keep shower caps provided by some hotels for covering key components, but I think you can now buy plastic wrap for food that has an elastic gathering.
Provide the cleaner/solvent.  This is what I use and can recommend:
http://store.yahoo.com/classic-motoring/ci-d32.html
Not sure what to recommend on the pressure washer.  If it has too much pressure, it can remove paint!  If you are interested in preserving any of the remaining factory painted nuts that indicate the factory checked the torque on certain components, I would not use pressure.
Some degreasers can discolor alloy components on the engine so using the right cleaner is important.
Hope this helps.
« Last Edit: July 25, 2004, 08:20:12 by Tom »
