Author Topic: should the air valve shut off compleatly when warm  (Read 2484 times)
erickmarciano
  • Canada, Quebec, montreal
« on: July 25, 2004, 20:37:13 »
when cold it sucks very loud and as the engine gets hot the noise goes away but when I block the air valve when hot the suction build up after about 2 seconds is it normal<I feel a litle vacum not much >?  . just replace the air valve thermostat on my 280sl and the base if the thermostat was larger I had to make the hole biger in the plate where it sits.
thanks
Erick
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Re: should the air valve shut off compleatly when warm
« Reply #1 on: July 26, 2004, 17:42:48 »
Hello Erick,
I recently replaced my fuel injector pump thermostat on my 1970 280SL.  Had the same issue as you regarding the plate the thrmostats sits on.  So like you I enlarged the hole so the thermostat fit snugly.  When hot the thermostat arm extends and pushes a cylindrical air valve which blocks air from coming in through the fuel injector pump air filter.  As I recall there are no o-rings or other sealing devices on the air valve.  I think this will create the potential for a very slight vacumm, especially as the air slide valve wears over time.  Given the lack of a more robust seal I think a very slight vacumm when warm is probably okay.  I'd be interested to hear what others say.
« Reply #2 on: July 26, 2004, 20:36:05 »
Hello Eric,
I agree with you Jeff. A bit of vacumm leak will make very littl difference.
« Last Edit: July 26, 2004, 20:36:50 by ja17 »
