Author Topic: A/C Compressor Belt Tension  (Read 3218 times)
studioPaGoNa
  • Japan, Kanagawa, Kamakura
« on: September 20, 2013, 05:21:35 »
Dear All
I need your help though I think that I read most of related threads but I am not clear.
I am currently under replacement of the York compressor by the Sanden rotary compressor using the conversion bracket.
During the replacement, I encounter one problem which is how to adjust a compressor belt.
I would like to know the adjustment method. Your inputs would be highly appreciated.
'68 US Version, Moss Green Metallic with Cognac Leather, Automatic
'95 R32 GT-R White
Re: A/C Compressor Belt Tension
« Reply #1 on: September 20, 2013, 05:33:41 »
Loosen the large center bolt on the tensioner pulley first, then use the 1/2" adjuster bolt to move the pulley to tighten or loosen the belt.
studioPaGoNa
« Reply #2 on: September 20, 2013, 08:15:32 »
Dear Joe
Thank you for your prompt advice. I am now very clear about your explanation and I will try it tomorrow.
Very Best, Koki
'95 R32 GT-R White
