Author Topic: Sluggish start off the line  (Read 3316 times)
travellerdogs
  • Canada, British Columbia, Bowser
« on: September 23, 2013, 00:25:20 »
I got my car running fine lately, just have one observation. I'm used to carburrated engines which have accelerator pumps and give you that initial shot  of fuel on accelerating off the line. My 69 280sl is sluggish until I get the rpm's up a bit then it accelerates  great. What would that problem indicate or are all these mechanical fuel injection systems like that. I've done the linkage tour all seems right on, could it mean i should move the timing up a bit, It's currently at 30 degrees at 3000 RPM, dwell is at 38 degrees. I haven't worked on it lately probably over a month so the specs I mentioned are what I vaguely remember. Just asking, Thanks, Carey
travellerdogs 1969 280SL,  1981 380SL:  1955 HD Panhead: 2007 HD Street Glide: 1956 Mercury Montclair, Black 2 Dr Htp; 1965 230SL: 2005 Pontiac Sunfire: 1993 Range Rover: 1977 450SL parts car:
Re: Sluggish start off the line
« Reply #1 on: September 23, 2013, 00:33:50 »
If you have an automatic, then normally you start in 2nd gear. Put the lever in "2" and the car will start in 1st gear -it makes a difference!  ;)
« Reply #2 on: September 23, 2013, 23:27:39 »
The throttle valve lever and the injection pump lever have to open at exactly the same time. If one opens before the other you will have a flat spot which is either lean or rich depending on which lever opens first.
30 degrees at 3,000 RPM isn't enough. That's how much the distributor moves ( 051 ) and you need to add the basic idle timing amount which is about 8 degrees for a total amount of 38 degrees at or near 3,000 RPM.
« Last Edit: September 24, 2013, 13:58:45 by Benz Dr. »
garymand
  • USA, CA, Meadow Vista
« Reply #3 on: September 24, 2013, 21:29:36 »
All good, and is your vacuum advance working, pull the line and the advance should go to ~8 and the rpms should go up a few hundred.
Gary
