Author Topic: Best fuel for my Pagoda  (Read 7684 times)
  • Australia, Victoria, East Ivanhoe, Victoria
« on: September 27, 2013, 10:54:06 »
Hi all what is the best fuel for my SL 230 , 1966 pagoda (Australian delivered  RHD )
Do I need a fuel additive?
GLC 300
E 300
1965 red 230 SL Auto RHD
 ,parchment interior
E type V12 RHD
Etype V12 1972 RHD FHC Auto
Re: Best fuel for my Pagoda
« Reply #1 on: September 27, 2013, 11:03:23 »
I find the best local fuel for my 230SL is the Caltex Vortex 98.
I dont add anything other than the highest octane that is available.
1972 MB 280CE Auto RHD 906G
2019 Izuzu DMax 4x4 Slide-on camper.
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
Jordan
  • Canada, ON, Jordan
« Reply #2 on: September 27, 2013, 12:04:33 »
If you can find a spot that doesn't have ethanol in the fuel, that would be good as well.  There are web sites dedicated to identifying stations (at least here in Canada and the US) that have ethanol free gas.
Marcus
66 230SL  Euro 4 speed
Larry & Norma
« Reply #3 on: September 27, 2013, 13:57:28 »
Had to put 10% Ethanol fuel in whilst in France last week, seems to run ok should
I expect problems?
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
« Reply #4 on: September 27, 2013, 14:03:16 »
I expect problems?
Not really. I think the whole issue of ethanol has been widely over blown by a small but vocal minority.
1988 560SEC
« Reply #5 on: September 27, 2013, 15:38:38 »
Including a bunch of engineers at MB....  ???
« Reply #6 on: September 27, 2013, 15:52:55 »
We have 10% ethanol here for several years. In that time, I've had zero problems with any of our gas powered equipment including old tractors, chain saws, 2 cycle equipment and lawn mowers. None of my cars have had any problems with it nor do I see any customer cars with any problems. Will there be something in the future? Maybe, but until that happens I'm not going to stand on the street corner shouting it down.
1988 560SEC
Larry & Norma
« Reply #7 on: September 27, 2013, 16:30:20 »
Don't think I will lose any sleep then ;)
2023 Ioniq6
2005 C230
jameshoward
« Reply #8 on: September 27, 2013, 19:42:31 »
I would tend not to agree with going for the highest octane rating. Here in Germany the highest is 100, but 98 is routinely available. Really high octane will cause the car to run hotter and harder [definition required ::)] Either way, I would not use 98 in my car, not least because (a) it's pricey, (b) you really don't need it, and (c) I think there's some thought that it could damage the engine.
I've used all sorts in my car, and it runs perfectly well on 95, and puts less stress on things...
James Howard
1966 LHD 230SL
garymand
  • USA, CA, Meadow Vista
« Reply #9 on: September 27, 2013, 20:59:02 »
This topic never goes away.  Here are some facts:  I've owned my 250Sl since 71.  I've always bought the cheapest gas from the lowest priced station.  Usually ARCO now, but where ever its low priced.    I only know American gas and at least here in California the gas formula is govenment regulated AND its all made in the same refineries AND pumped down the same pipes to the outlets.  Perhaps in less regulated times and places gas fomulas were more varied, but not here and for the last 30 years.
I only feed her 98 when its above 90 F and I'll be riding her hard because she might ping.  When I can't up the octane on a hot day of running hard, I just back off the timing a few degrees, which is simple on the 230/250, a little harder on the 280 to guess how far to go and how to get it back.
I just took her head off at 110k for a chain and gasket replacement.  Her motor had about 20K on it when I took over.  So with 90K of my taste in gas, and oil), intake valves were clean like new and the exhausts had just a light film of deposits.  I was surprised, but the gasket was getting soggy so a good time to change it.  She loves to run and I run her hard.
She doesn't seem to care what gas she drinks.  It all seems to be the same to her.  Her power seems the same. 96 or 98 other than pinging when the advance is not reduced 3 or 4 degrees, neither she nor I can tell any difference.
Gary
Early 250SL German version owned since 71, C320, R350, 89 Porsche 944 Turbo S
« Reply #10 on: September 27, 2013, 21:29:50 »
There must be differences in how octaine rating is done from one place another. The highest I can get here is 94 which I think uses the RON method for rating.
1988 560SEC
« Reply #11 on: September 27, 2013, 21:32:05 »
I believe there is several different ways of listing the octane.
We have basic 91 then there is a premium 95 and a special at 98 but not all service stations sell the 98.
Most cars here will run on 91 but the newer cars are s=recommending 95.
garymand
« Reply #12 on: September 27, 2013, 23:08:07 »
Yes we can only address our local gas supply.  I'm an experimenter at heart and have tried to test and verify what I think.  (Just because I think it doesn't mean its true)  I was hesititant to say low test/hi test in favor of numbers.  I've read all the opinions on gas additives and cleaners I just can get any proof of benefit and to the contrary when I pull my motors apart, I see no adverse conditions in the combustion chamber or the valve surfaces from ordinary plain low octane gas with no additives.
I even run low octane in the 560 and 320 both say the require hi test.  Again, I only run high test when there is a risk of pinging and I drive 100 miles a day with an elivation change of 1700 feet.   I give these girls good hard runs and have a lot of fun doing it.
The 560 only pings at >95 F. that's when it gets hi test,  I've never heard the 320 ping, but wify drives that most times.  The 944 pings >100 F.  Its a low compression w/turbo so it loves low test normally.
Gary
Re: Best fuel for my Pagoda/show and shine
« Reply #13 on: October 03, 2013, 09:36:52 »
Hi all,
Thank you forthe very helpful information.
Thanks also to Garry for dropping off my membership in an envelope with a mint Pagoda postage stamp!
Are there any "show and shine " or concourse  days listed for Australia?
I would like to catch up with local owners if the opportunity presents itself.
GLC 300
E 300
 ,parchment interior
E type V12 RHD
« Reply #14 on: October 04, 2013, 02:41:48 »
James,
We just had (March 2013) a 50th Pagoda gathering in Canberra where we got 58 cars. There are none planned.   I suggest you put an expression of interest on the " events " section of the forum and see who would be willing to gather.   I did it about 18 months ago and we got 7 together at Hanging Rock for lunch. Once you have some numbers then work out a gathering place and it will happen, which is exactly what I did off my own bat.
Paul99
  • 230 SL White. 1966.
« Reply #15 on: October 05, 2013, 09:57:50 »
I run mine on 98 Ron as on the lower Ron it pinks.  I notice in the mercedes car handbook it states 98 Ron min.
