Please check out joining the
Emergency Contact List
for help during your travels!
Steering noise
Topic: Steering noise (Read 3319 times)
iftykhan
Steering noise
September 29, 2013, 17:44:01 »
I am looking for advise on a noise when I turn the steering wheel.
It's a low graunching sound which seems to occur when the car has warmed up.
I did recently grease the various nipples on the front of the car but the noise is still there.
Any help would be appreciated.
Ifty
awolff280sl
Full Member
Gold
USA, FL, Sarasota
Re: Steering noise
September 29, 2013, 22:37:42 »
Could be due to a sharp bend or even a kink in the hose that goes from the bottom of the PS reservoir to the pump.
See
http://www.sl113.org/forums/index.php?topic=10980.0
Andy Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
Larry & Norma
Full Member
Platinum
United Kingdom, England, Southampton
Re: Steering noise
Reply #2 on:
September 30, 2013, 07:37:17 »
It was the steering idler bush on mine when it was making a similar noise, also only
when the engine was hot.
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
gerster
Re: Steering noise
Reply #3 on:
September 30, 2013, 17:46:08 »
Did you check your oil level of the steering pump Ifty?
iftykhan
Re: Steering noise
Reply #4 on:
September 30, 2013, 20:32:35 »
Thanks for your responses gents.
I have only greased various points at the front end as yet but will look at your suggested causes within the next week or so and report back.
Thanks again,
Ifty
Associate Member
Platinum
Canada, ON, Port Lambton
Re: Steering noise
Reply #5 on:
October 01, 2013, 02:07:43 »
Sounds like air in the system caused by low oil level from a leak somewhere. You should note that once you have air trapped in the system it will continue to push fluid out until you remove any trapped air.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
Steering noise
