Author Topic: need to raise the cold idle.....  (Read 2912 times)
erickmarciano
  • Canada, Quebec, montreal
« on: July 27, 2004, 08:48:35 »
the warm up device has a new thermostat and does shut off when cold but my proble is the cold idle is at 800rpm would removing the shims at the base make it more rich even when hot or just during warmup?
thanks
Erick
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Re: need to raise the cold idle.....
« Reply #1 on: July 27, 2004, 13:35:17 »
Hi Erick,
I think you mean the warm up device shuts off the air supply when warm not cold.
You have the 1971 version of the emission control system.  There is a low coolant temperature switch located in the block on the fuel injector pump side of the engine.  When the engine is below 62 degrees F the switch should be closed.  When this switch is closed vacumm pressure is released, by the two way valve, on the distributor and timing retard is removed.  This creates quite a rpm pickup when the engine is cold.  You can simulate this action by jumpering the low coolant switch wire to ground.  My switch is broken in the open mode as I suspect many others are.
erickmarciano
« Reply #2 on: July 27, 2004, 14:02:25 »
I have a euro 1971
thanks
Erick
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
« Reply #3 on: July 27, 2004, 16:14:51 »
I removed one shim from the bottom of the thermostat housing about three years ago, in order to lean out the mixture across the entire range when the engine is warm. This I did on the basis of information from the old Yahoo! site. My car runs close to 850 RPM when the engine is cold OR warm, there is not very much difference. I don't think having it at 800 is a bad thing, unless it has a tendency to stall.
