Author Topic: Trunk gasket - aftermarket vs. OEM  (Read 9838 times)
« on: July 27, 2004, 18:06:29 »
I just purchased what I assume is an aftermarket trunk gasket. Does anyone have any experience with the standard aftermarket piece and how it compares to the OEM piece? I know it's less money, but it also appears to be a bit too wide to fit perfectly in a Pagoda. Am I correct about this?
pkiefert
Re: Trunk gasket - aftermarket vs. OEM
« Reply #1 on: July 27, 2004, 18:39:54 »
uhh, whadya mean the "standard" aftermarket?  I bought one from a place in California, it could be an Asian copy for all I know. It does have the right rubber density and contour and approximately the same color as the original, but it's a bit blacker. All my original rubbers have that lightened/faded black rubber look.  I may have read on these forums that some originals had a greyish color. I just had to cut it for length. It was about half of the MB cost. I used 3M Weatherstrip to install.
« Reply #2 on: July 27, 2004, 19:03:13 »
Doug, from what I've read up on the weather strips is that there is usually an issue with with fitment especially the windshield. If too wide you are refering to lenghth I would cut one of the ends to make it smaller. If too wide meaning thicker I think once installed and trunk closed the rubber may be visible in the gap. This being the case your trunk lid may not be flush with the fenders. About 11 years ago Buds Benz was selling rubber kits. You may want to chek it out.
« Reply #3 on: July 27, 2004, 21:23:51 »
The gasket in my current Pagoda is, I believe, an aftermarket piece. It's a little too fat and has a wider lip around the perimeter than the gasket on my previous SL.
« Reply #4 on: July 29, 2004, 18:10:32 »
It's easy to install the trunk seal incorrectly and wonder why the lid doesn't close very well. I think the repro trunk and door seals are OK but the windshield seal is junk. Unless they fixed the problem which is that the seal is too long and won't fit, I'll only sell originals.
I warned everyone about this quite a while back - it still stands.
Daniel G Caron
« Reply #5 on: July 30, 2004, 08:41:08 »
I found it takes a little bit of fiddling to get the trunk seal in proper position under the metal lip.  Push it into the upper corner under the lip with your finger tips, then into the lower corner.  When it goes in right, you'll know it.  Once it's all in, it's a good idea to lubricate the contact surface with silicone.  If the lid/seal contact can't slide a bit, it can bunch up the seal and distort the lid at front center.
« Reply #6 on: July 30, 2004, 12:05:11 »
Some aftermarket weatherstripping is good, most if it isn't. When in doubt, get genuine MB at wholesale.
tom in CA
« Reply #7 on: October 27, 2004, 08:44:52 »
I'm about to install the OEM gasket I recently purchased. (Thanks again, Tom Hanson.) I'm really glad I decided to do this since I noticed some surface rust forming underneath the old gasket after I removed it. So I have 2 questions for everyone, one regarding prep for installation and another regarding proper fit:
1. Will the glue adhere to that greyish rubber without any special pre-treatment? Do i have to use any kind of solvent to clean it first?
2. Should you be able to see some of the trunk gasket (especially up around the top of the lid) when the trunk is shut?
Thanks for your insight/advice.
sammyr
« Reply #8 on: October 27, 2004, 10:04:47 »
I used the original and it fits perfectly. Dont use aftermarket it never fits good. Watch out I heard silicone can rust the metal (Im not sure). I used some black adhesive that I got from a Benz shop special for the seals.
1969 MERCEDES 280SL
WHITE ON BLACK/ BLACK HARD TOP
« Reply #9 on: October 27, 2004, 13:35:15 »
Hi Douglas. When I redid my trunk gasket, I went with OEM. It struck me as scary to get it just right so I let my mechanic do it! (not really sure he did it perfect either but it keeps water out of the trunk!)
He used 3M adhesive. It comes in yellow and in black. Use the black if you can find it.
And in my case, a bit of the rubber is visible when the trunk is shut.
correction: The inner edge of the rubber appears a little higher than the outer. Make any sense? Again, not sure its done exactly right.
« Last Edit: October 27, 2004, 15:49:51 by J. Huber »
« Reply #10 on: October 27, 2004, 13:51:39 »
I had read posts on the ill fitting aftermarket windshield gasket. I figured that most likely this problem plagued all these non oem gaskets.
71 pagoda
« Reply #11 on: October 28, 2004, 05:29:46 »
Doug,
I just spoke to Wolfgang about this exact subject.  My car is at his shop now. He told me to go with original MB seal. He also said that most people put the seal in incorrectly.  The inside should be slightly higher. It should look like the rubber seal is  almost on its side but not quite that far. If this doesnt make sense, Call his for a better explaination.
Larry
White 71
« Reply #12 on: October 28, 2004, 11:27:34 »
Larry, come by for a visit when you pick up the car from wolfgang...I'm only a few miles away.
-Lewis
66 230 sl 113042-10-016238
67 saab sonett II #43 of 258
00 saab 9-3 viggen conv
02 saab 9-5 aero
« Reply #13 on: October 29, 2004, 16:35:20 »
What is the approximate difference in price, aftermarket vs. genuine MB for these rubber pieces? Can't be that much, can it?
1964 356C
« Reply #14 on: October 29, 2004, 21:34:09 »
When I had my 250sl ZF5 Buds Benz were selling complete rubber kits.  Don't know if they stil do but it seems you could save a few bucks that way.
« Reply #15 on: October 30, 2004, 10:59:05 »
The rubber kits are still available. I used Miller's and it was much more cost-effective than buying each piece individually (that was 98 but I assume it still is).
« Reply #16 on: October 30, 2004, 15:08:33 »
Does anyone know how much price difference there is in these original vs. aftermarket pieces?
1964 356C
« Reply #17 on: October 30, 2004, 15:12:08 »
Ed as far as your car is concerned you should go all the way and get OEM. :D   You're going to wind up with one "S W E E T  ;)   R I D E"  Keep it that way.   8) Oh yeah! 8)
« Last Edit: October 30, 2004, 15:13:29 by hauser »
