Author Topic: No rev. counter afte HotSpark install  (Read 3612 times)
laegaard
« on: October 07, 2013, 09:06:08 »
Hi
Just installed a HotSpark kit on my 1970 280SL, but now my rev counter is not working.. Any advice on how to fix that ?
Mads
GGR
  • USA, DC, Washington
Re: No rev. counter afte HotSpark install
« Reply #1 on: October 07, 2013, 10:13:16 »
That is strange, as on a W113 the rev counter is cable driven. If your car has been fitted with another rev counter, or if your car is not a W113 (say a late w111 coupe for example), then it is possible. There are ways to sort it out but I would need to know more about the rev counter you have and the type of ignition you had before installing the new one.
RBYCC
« Reply #2 on: October 14, 2013, 17:26:50 »
I have the Hot spark in an 009 distributor in my 1971 280SL.
No problem with the tachometer.
There is a correction if you have a signal style tach, not a cable driven tach:
http://www.hot-spark.com/Tachometer-Fix.pdf
