Author Topic: What do you use in your rear axle ???  (Read 6745 times)
jlennon3
« on: October 10, 2013, 00:15:16 »
It's time to replace the oil in my rear differential, and I'm thinking about using the Lubrication Engineers Duolec 1605. I contacted the local LE representative and this is the product they recommend for our cars. It's a GL-5 gear oil, SAE 110.
Any opinions or recommendations??? I've heard Redline is also a good product, and I'm certain there are others as well.
I'm kind of leaning toward the Lubrication Engineers product because I've used their Almasol gear oil in the past and it seemed to work well
awolff280sl
  • USA, FL, Sarasota
Re: What do you use in your rear axle ???
« Reply #1 on: October 10, 2013, 00:35:38 »
REDLINE 75W90 GL-5 synthetic gear oil
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
« Reply #2 on: October 10, 2013, 01:18:01 »
Red-Line is good but not localy available to me. I've used Ams/Oil and often use Quaker State or other synthetic gear lubes usually in 80W90 or similar. I can't think of any reason to use a petroleum lube anymore.
My car has a LSD and I had to use an additive along with the synthetic I used. It would growel every time I turned a corner but is now fairly quiet after adding this special stuff. I assume the groweling noise is the clutches slipping inside the diff carrier.
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
« Reply #3 on: October 10, 2013, 05:23:43 »
I use Mercedes Benz Universal Hypoid 85-90 but I have a Limited Slip Diff so the stuff I bought has an additive called Alkenylamine which seems to be common in oils for Limited slip diffs.    The stuff is crazy expensive but is apparently formulated specially for the mercedes limited slip diffs.  Based on my research, if you don't have a LSD, top quality hypoid 75-80w90 is your best bet as recommended by Dr. Benz and awolff280sl above.   I was strongly cautioned about using cheaper noname hypoid oils by a heavy duty mechanic / hot rod guy.
Ian
69 280SL
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
96 F-150
08 NPS50
12 Pro 4X
« Reply #4 on: October 11, 2013, 23:24:15 »
You have a LSD?  They're more rare than the 5 speed tans option. Not that I'ver seen many 5 speeds but I've only had one car with that option in 35 years. I only know of a couple other examples.
