Author Topic: Mystery Seepage on Left side of Engine Block  (Read 4288 times)
Theclaw
« on: October 27, 2013, 13:33:28 »
I've only had this car for a short time, hardly drove it more that just around town.  http://www.sl113.org/forums/index.php?topic=18941.msg132335#msg132335
While I was changing the oil before putting it into storage for the winter I noticed some white seepage on the left side of the engine block.  I'm pretty sure this is a bad head gasket, but maybe this is something that's peculiar to these cars. Any advice would be helpful.
Probably should say that it's got a little over 100k miles.
Thank you,
Jeff
IMG_8880 by theclaw900, on Flickr
IMG_8879 by theclaw900, on Flickr
« Last Edit: October 27, 2013, 13:48:31 by Theclaw »
Theclaw
Re: Mystery Seepage on Left side of Engine Block
« Reply #1 on: October 27, 2013, 13:51:17 »
Been searching the forum and it seems like head gaskets are a common topic around here.  My next questions are 1) What's the risk of running the engine like this?  2) Worth trying to re-torque the head or with 100k is this something you have to do anyway?
Thanks again,
mbzse
« Reply #2 on: October 27, 2013, 18:17:18 »
Quote
...Worth trying to re-torque the head.../..
Jeff,
Typical head gasket leak, coolant is leaking out onto the side of your block. Possibly also inwards, into the cylinder.
A re-torque of the head bolts is useful, actually it is part of regular maintenance on engines of this era. Perform every 30 000 km or so.
One bolt at a time, loosen and torque to spec. Best done on a hot engine.
/Hans in Sweden
/Hans S
jameshoward
« Reply #3 on: October 27, 2013, 18:22:36 »
As Hans says. There's a set order in which to tighten the bolts. The info is probably on the site, if not in a Haynes manual or the Merc manuals of the period (BBB - Big Blue Book). If you want to do this and can't find the info, just shout.
James Howard
1966 LHD 230SL
Theclaw
« Reply #4 on: October 27, 2013, 19:47:59 »
Thanks. I've got a Haynes manual and picked up the Bentley Technical Companion.  Where would I find the Big Blue Book?
awolff280sl
  • USA, FL, Sarasota
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
Theclaw
« Reply #6 on: October 28, 2013, 21:26:08 »
Thanks Andy. That link was very helpful. The manual worth the price of full admission!
Jeff
