Author Topic: How much yardage of MBtex for bottom of hardtop?  (Read 3259 times)
rutger kohler
« on: October 28, 2013, 02:15:45 »
Hi, my bamboo MBtex around the bottom of my 280SL hardtop is looking tired, as are the edges of the MBtex on my soft top cover lid.  Does anyone have a good idea of how much replacement MBtex I should order plse? I see Budsbenzs supply it by the yard at 60" wide.
1969 280 SL Manual gear shift
1972 280SE 3.5 auto
rutger kohler
Re: How much yardage of MBtex for bottom of hardtop?
« Reply #1 on: November 09, 2013, 22:21:55 »
The answer is one yard accoding to David Latham of Budsbenz.  I am going ahead with this.
1972 280SE 3.5 auto
« Reply #2 on: November 11, 2013, 18:04:06 »
You can buy the material for the hatch cover already pre cut.
gvillayandre
« Reply #3 on: November 14, 2013, 15:31:48 »
I will need to do this change also.
Any instructions about to remove and replacement of this tex?
I don't see any screw or bolt to remove this part.
Thanks in advance
rutger kohler
« Reply #4 on: November 15, 2013, 07:54:07 »
Hi, thanks for the pre-cut tip however as I will have plenty left over from the underrside of the hardtop I figure it should be easy to cut myself,  The exisiting MBtex on the soft top hatch lid is good enough to provide a pattern.
1972 280SE 3.5 auto
