Author Topic: cooling fluid reading  (Read 5227 times)
jan lauwers
  • Belgium, Antwerpen, Geel
« on: November 03, 2013, 10:47:26 »
Hello everybody,
I am struggling with something pretty basic: I can't find the MIN and Max readings on the cooling fluid expansion tank of my 280 SL (autom. 1969). I know that the fluid level is too low…. but how far should I top it up? Does anybody have a picture of such a tank showing the readings?
Many thanks… and have fun!
Jan
Jan Lauwers, Geel, Belgium
Grey (Used to be white)  280 SL 1969
Larry & Norma
Re: cooling fluid reading
« Reply #1 on: November 03, 2013, 11:34:13 »
I just establish that 1) I can see fluid and then 2) inserting middle finger results in end third gets wet :-\
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
« Reply #2 on: November 03, 2013, 17:18:11 »
Larry is 100% correct, there is no reading level, just make sure that the tank has fluid to near the top.
Robert Hyatt
Williamsburg, VA.
Rolf-Dieter ✝︎
  • Canada, ON, London
« Reply #3 on: November 03, 2013, 19:16:55 »
I don't think near the top is correct  ??? That the overflow tank has no level indicator is correct.
I make sure that the overflow tank is at 1/2 level it needs to be that way or you will have water overflow all over the engine and on the floor when the engine is hot.
jan lauwers
« Reply #4 on: November 03, 2013, 20:25:46 »
Thanks a lot guys!!! :)
Jan
Rodolfo
« Reply #5 on: November 03, 2013, 21:39:48 »
I will take a look tomorrow.
( Ik kijk er morgen eens naar en kom er op terug)
