Author Topic: confusing- engine running bad  (Read 16551 times)
Re: confusing- engine running bad
« Reply #25 on: November 19, 2013, 15:52:15 »
I just changed out the wires on my 280 SL and they are stranded copper core (takes about 4.5 meters to do the whole thing). The plug ends I have are stamped with 5K Ω. They all tested in the same range, so all the plug ends were re-used.
Basil
« Reply #26 on: November 20, 2013, 20:48:19 »
Even though there was a 11KOhm boot on one of the plugs, the car ran super whith a cold engine.  ::)
« Reply #27 on: November 21, 2013, 15:35:00 »
Depending on whether your ignition system is the later factory electronic, or the standard early ignition, your spark plug connectors may be 1,000 ohm or 5,000 ohm.  The early original 1,000 ohm resistor ends were all plastic. All original spark plug wires were solid stranded copper wire (tin coated). Original style wire could be ordered by the meter from the dealer at one time (part # 110 159 1818) The ends on the original sets, simply screw on or off and can be replaced.  All spark plug connectors should be straight. If you have a right angle connector on #1 this is not correct but will work fine. MB carbureted engines of the era used a right angle connector at #1 because of the location of the distributor on the carbureted engine.
later spark plug connectors with factory transistorized ignitions ..........  5,000 ohms
earlier spark plug connector with standard ignitions ..........................   1,000 ohms
resistance of rotor.......................................................................    5,000 ohms
coil cable end at coil ...................................................................    1,000 ohms
coil cable end at distributor..........................................................     1,000 ohms
Now if you are using the incorrect resistor spark plugs add 5,000 ohms resistance.
If you are using the incorrect resistor style spark plug wires add 5,000 ohms resistance.
The factory allows a total resistance from the coil end of the coil wire to the end of the spark plug of 13,000 ohms resistance ( early non-transistorized ignitions). You can measure the resistance of each component separately and add them on each cylinder if you like. 19,000 ohms total resistance is allowed on the latter cars with factory electronic ignitions. Or replace any one component which deviates more than 25% from specs.
You can also assume that if you  are using more modern coils, or aftermarket transistorized ignition systems with much higher output voltage, then the 19,000 ohm total resistance figure can also apply to your  earlier engines.
Example...If your are using resistor spark plugs, resistance carbon wires, then you are already out of factory specs on maximum resistance. (rotor 5,000 ohms + resistance spark plugs 5,000 ohms + resistance carble spark plug wires 5,000 ohms, etc, etc total 15,000 ohms +)
Ohm meters are inexpensive and easy to use.  A resistance check on all ignition components should be conducted during a standard tune up or trouble shooting session.
garymand
  • USA, CA, Meadow Vista
« Reply #28 on: November 21, 2013, 21:10:10 »
Thanks Joe, well presented.
Gary
Basil
« Reply #29 on: November 25, 2013, 18:47:18 »
I would like to thank all of you for your input on this thread. Today I visited an expert on Pagodas in The Netherlands. Messr. van Dijk in Lisserbroek.
They only work on older type Mercedes.
At first the valves were set properly, check on the distribution chain, then ignition, which we replaced by an 1 2 3 electronic version, linkage tour and ONE shim extra under the altitude compensator.
Engine runs very smooth and picks up at the whole RPM range !!  ;)
I am happy !!
Paul.
« Last Edit: November 27, 2013, 20:42:14 by Basil »
« Reply #30 on: November 27, 2013, 00:01:13 »
Most excellent. I have had the opportunity to stop at the van Dijk shop. They do very nice work. Severa good friends of mine have their cars taken care of there.
Basil
« Reply #31 on: November 27, 2013, 20:49:09 »
Right Jonny, very nice people too.
Bought myself a Christmas present there. A Becker Europe radio !!
