Author Topic: Injection Pump Oil Leak  (Read 4204 times)
ctaylor738
  • USA, VA, Falls Church
« on: November 16, 2013, 15:39:51 »
My four-year 280SL project-in-a-kit is finally "almost" finished.  I took it for its 20 mile first drive a couple of days ago and when I put it back in the garage I noticed a serious puddle of oil where it had been sitting.  I checked it out and found that oil was dripping off the idle mixture adjusting knob on the back of the injection pump.  I took the adjuster assembly off and found that half of the o-ring that seals the adjuster shaft had gone missing.
This o-ring sits in a recess on the inside of the plate that holds the adjuster and is held in place by the tension of the spring.  I replaced it with a 4 x 1.6 mm o-ring, and no more leak.
I highly recommend replacing this piece if you have the adjuster off the pump or if you are installing a pump.
Cheers,
CT
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
Rolf-Dieter ✝︎
  • Canada, ON, London
Re: Injection Pump Oil Leak
« Reply #1 on: November 17, 2013, 01:19:14 »
Thanks for the tip CT!
« Reply #2 on: November 18, 2013, 21:14:43 »
You are so right Chuck. Mine was leaking as well and had to replace it. Easy to do once you have it apart. I went a little further and used a Viton o-ring. The standard Nitrile (buna-N) o-ring is OK and resists oil, but has a limited temperature of 225-250*F. So over time, it hardens and will leak. Viton is highly chemical resistant and resists heat to 400*F. Yes it is more expensive, but on that small of a part, its only pennies.
If this was a static o-ring (meaning it never moves), Nitrile is OK. But it does become unseated everytime you make an adjustment.
One more tip along this line. Everytime you press the adjuster in, a little bit of oil drips out. I always take an oil rag and wipe the bottom side of the adjuster when I make an adjustment. A little over-the-top I know.
