Author Topic: Hot-Spark or Pertronix ignition  (Read 7413 times)
kampala
  • USA, CA, Beach Cities
« on: December 02, 2013, 20:55:21 »
I want to remove my points and install an in-distributor hall-effect system.  I have found and read quite a bit about Pertronix on this forum but have found very little about Hot-Spark.  It seems a few folks on this forum have the Hot-Spark and it would be great to hear some feedback.
The car is a 250sl, manual shift with an 051 distributor.
thanks
250sl - later - manual
280sl - 1971 - Auto - LSD
Larry & Norma
Re: Hot-Spark or Pertronix ignition
« Reply #1 on: December 03, 2013, 15:55:53 »
123 is the way to go
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
dante53
« Reply #2 on: December 03, 2013, 20:17:18 »
I installed a Hot-Spark kit on the 051 distributor of my 230SL a month ago. Installation was very easy and up to now it's working flawlessly but I've done very little  mileage since.
jedwards
« Reply #3 on: December 04, 2013, 04:06:28 »
I installed the Pertronix unit in my '67 250SL as well as in my Porsche 911 and they are terrific value and work perfectly. Simple to install but you might need to reset your timing if the mounting plate needs some adjustment.
kampala
« Reply #4 on: December 05, 2013, 21:35:43 »
Thanks for your responses .... appreciated.
naniroma0
« Reply #5 on: December 05, 2013, 23:51:24 »
hallo,
http://stores.ebay.ie/Simonbbc-Ignition-Solutions?_trksid=p4340.l2568
hola,
mi pagoda monta este y mas de 15.000 kilometros sin problemas
saludos.
hello,
my rides this pagoda and over 15,000 miles without problems
Greetings.
« Last Edit: December 06, 2013, 08:42:15 by Peter van Es »
RBYCC
« Reply #6 on: December 09, 2013, 18:33:23 »
Hot Spark in an 009 distributor.
No modification required like Pertronix in the advance plate area.
So far so good.
