Author Topic: Correct routing for B/U light switch wiring?  (Read 5626 times)
W14
« on: April 05, 2003, 22:54:30 »
Hi Group,
I am wondering if the wiring to the back-up light switch at the transmission is correct on my car: it exits the firewall near the clutch fluid hose, then goes underneath the trans., and comes up the right hand side to the switch on the right-top of trans.
Is this correct?
Will W14
1965 230SL 4spd
Victoria,BC
Re: Correct routing for B/U light switch wiring?
« Reply #1 on: April 07, 2003, 02:32:51 »
Mine was hanging below the gearbox as you say but I have now routed it 'over' the gearbox.
Don't know which is correct!
hobel 65 230SL
jalopyno 68 280SL
W14
« Reply #2 on: April 07, 2003, 23:55:44 »
Thanks Naj,
I'll probably route mine that way as well - it will be a lot more protected that way.
Will W14
1965 230SL 4spd
Victoria,BC
