Author Topic: 230sl I just bought can't open trunk HELP!!  (Read 5202 times)
matthewjames1982
« on: December 19, 2013, 03:06:41 »
I just bought a 1966 Mercedes 230sl and I can't open the trunk I push the button and it goes all the way in (so i don't believe its locked)  but the trunk doesn't open.  Anyone have any tricks I know I have scene people say they drill out the lock but that seems to be only if the button is locked which I don't think it is please help thanks!
jpsenft
  • USA, MD, Silver Spring
Re: 230sl I just bought can't open trunk HELP!!
« Reply #1 on: December 19, 2013, 03:29:42 »
If you feel no resistance or minor spring resistance, it is locked.   When unlocked, you will feel much more resistance as the push button releases the latch.  Try turning the lock 180 degrees with the key and see if it feels any different.
1965 230SL
Silver Spring, Maryland
matthewjames1982
« Reply #2 on: December 19, 2013, 13:50:18 »
CLOCKWISE OR COUNTER CLOCK WISE?
jameshoward
« Reply #3 on: December 19, 2013, 14:21:04 »
CCW I think, but whatever works.
Are you sure you have the correct key? It's quite possible to end up with 5 keys for your car if POs have messed around with the locks.
James Howard
1966 LHD 230SL
Rolf-Dieter ✝︎
  • Canada, ON, London
« Reply #4 on: December 19, 2013, 15:56:24 »
If you just purchased the car then you did not do your homework properly :) one step is to open the trunk roll the rubber mat back and see if there is no rust on the trunk floor. Just saying :)
As for your key to the trunk, (as jpsenft mentioned), do you have the right key? How many keys do you have … I have 4 keys
Ignition … no markings needed it is the largest key.
Doors ……. Stamped "D"
Trunk ……. Stamped "T"
Gas Cap … Stamped "G"
Keys can be tricky, for example when I picked up my car (one item I did not check was all the locks and keys since the previous owner only gave me the ignition key for the test run). When I picked up the car I needed to tank and low and behold I tried to open the gas cap without success. I finally had to phone the previous owner, he came and gave me a lesson how to unlock the gas cap. :) So as I said it can be tricky.
If you have no success, I recommend you go to a locksmith or a Benz Dealer, find a seasoned Mechanic and you should be okay then.
scoot
  • USA, CA, Altadena
« Reply #5 on: December 19, 2013, 18:25:11 »
If you don't have any keys that turn the trunk lock (which I find hard to imagine given that the previous owner must have been able to open the trunk) get the data card on the car which will have the key codes and order a new key for the trunk.    You can order the key from MB or from keymen.com (I might have that spelled wrong) or from any key company that will cut keys to code.
Scott Allen
'67 250 SL (early)
Altadena, California
« Reply #6 on: December 22, 2013, 02:55:29 »
I have a way to get into anyones trunk but I'm not going to explain how I do it here for obvious reasons. PM me or give me a call and I will explain it to you.
