Author Topic: Fuel Hose Seal  (Read 2589 times)
dirtrack49
Fuel Hose Seal
« on: December 26, 2013, 17:17:41 »
Hi All,
Replacing fuel hoses on my 66 230SL.
Can anyone tell me the size of seal that seals off the banjo fitting at the fuel dampner? Does it require two seals, aluminium or copper? Is there a part number?
Tom L.
bsimaz
Re: Fuel Hose Seal
« Reply #1 on: December 26, 2013, 21:01:28 »
banjo fittings always require two washers.  One on each side of the fitting.  Usually aluminium.
dirtrack49
Re: Fuel Hose Seal
« Reply #2 on: December 28, 2013, 14:33:51 »
Thanks bsimaz for the info.
I found out the size is 14mm x 20mm x 1.5mm aluminium seal. And yes, it requires two seals.
Thanks again,
Tom L.
