Author Topic: Soft Top Spring fitting help  (Read 7289 times)
jedwards
« on: December 28, 2013, 09:39:28 »
Gentlemen,
I have purchased new large soft top springs but am not sure how to fit them.
The springs are made from 3.5mm diameter wire but the  hole into which they (appear) to need to be inserted, is only 2.5mm diameter.
The option seems to be to drill out the holes, but I have read much of broken spring arms, so am not sure if I should do this and thus weaken the arm.
What is recommended?
Re: Soft Top Spring fitting help
« Reply #1 on: December 28, 2013, 09:42:55 »
I thought there were two springs but just looked and here is the setup for the 230SL
May help
« Last Edit: December 28, 2013, 09:50:59 by Garry »
Larry & Norma
« Reply #2 on: December 28, 2013, 10:11:58 »
The spring you have looks way too big, check with your supplier.
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
mbzse
« Reply #3 on: December 28, 2013, 10:54:31 »
Quote from: jedwards
.../... the hole into which they (appear) to need to be inserted, is only 2.5mm diameter.../..should I drill out the holes.../...
No, the large spring does not go there! That position is for the little, second spring. There were three major versions of the soft top frame in our cars (plus a fourth, very early version, see text in our Tech Manual under heading "Soft Top").
You have the second version.  Pictures here (third version) show second spring attached between "A" and "B"; and you see by "A" is where it fits in the 2,5mm hole.
BTW, what happened to your original springs?
Garry's pictures of a 230SL (Reply #1) show the first version frame, which did not feature the second, smaller spring and which had snap locks on each side on the lower rear bow.
/Hans in Sweden
« Last Edit: December 28, 2013, 16:53:10 by mbzse »
/Hans S
jedwards
« Reply #4 on: December 28, 2013, 23:12:21 »
Thanks Hans
That piece is missing on my car, and appears to have broken off some time ago. that bar and both sets of springs were missing from my car when I acquired it.
Is that part available?
regards
Jeff
« Reply #5 on: December 28, 2013, 23:26:20 »
This piece is no longer available from the suppliers and is a common broken part.
http://www.sl113.org/forums/index.php?topic=13274.0
Look at this post, you may want to go to Bob and see if he still has the drawing that he used to make a new lever.  Otherwise it may be a case of putting up a wanted advert and see if there are any parts around.
