Author Topic: Brake Booster Eccentric Adjustment  (Read 2599 times)
Steven A
  • Australia, Western Australia, Cottesloe
« on: December 30, 2013, 06:52:52 »
Hi, hoping some-one can enlighten me re the eccentric adjustment at the bottom of the brake booster.   I have not been able to find any reference in Haynes or others as to how this is to be set (or whether it is a "don't' worry about" bit).
The eccentric is on the lower end of the brake booster flange casting (please see attached pdf).    With the brake booster now re-installed, the side shown in the photo is not accessible, however on the western end there is a slot.
Thanks for assistance, Pagoda SL Group do a great job with sharing information and past experience.
Regards
Steven
1964 230SL Manual RHD
1957 Series 1 Land Rover
1975 Range Rover
Steven A
Re: Brake Booster Eccentric Adjustment
« Reply #1 on: December 31, 2013, 06:46:19 »
Hi all
A follow up on this one.   Decided to take the booster back out and have a look before final tightening/reconnecting master cylinder and brake lines etc.
When the slot (this is on the central side of the bolt at the base of the booster flange that holds the booster lever) is vertical (north south) this has the eccentric 1/2 way between minimum and maximum location of the booster lever.  Horizontal is either max or min.    There is about 1 to 1.5 mm adjustment available.   I went 1/2 way so I could adjust more or less leverage.
Hope this helps some-one else one day!
Regards
Steven
1975 Range Rover
