Author Topic: rubber grommets for Nardi Steering trim ring  (Read 5658 times)
rmmchl
  • USA, WV, Charleston
« on: December 31, 2013, 02:08:47 »
the trim ring that holds the horn button on my Nardi steering wheel has a series of holes on the backside that fit over corresponding  nuts on the steering wheel housing. I think there may be 6 or so, of them. 2 of the holes have a small rubber grommet in them to hold the trim ring snug over the bolts. Then the horn button snaps into this. Does anyone know where I can find these rubber grommets, and also does anyone know if each hole was supposed to have a rubber grommet. I only have grommets in 2 of the holes?
« Last Edit: December 31, 2013, 04:19:10 by rmmchl »
michael romeo
1967  250sl
signal red
Louiehenry
Re: rubber grommets for Nardi Steering trim ring
« Reply #1 on: December 31, 2013, 06:00:52 »
Mine has two as well, the horn actually seems to snap into the column on mine, and that hold the ring in place
rmmchl
« Reply #2 on: December 31, 2013, 10:45:17 »
One of mine is worn. Thanks for letting me know yours has only 2 also. Seems like all of the holes should have the grommets. It would make the trim ring fit tighter.
michael romeo
1967  250sl
signal red
Louiehenry
« Reply #3 on: January 01, 2014, 01:24:23 »
That would make sense! I may consider adding them now that I think about it!
« Reply #4 on: January 01, 2014, 15:16:05 »
rmmchl
« Reply #5 on: January 01, 2014, 17:10:20 »
they aren't  O-rings, but a specialized rubber grommet, that looks like a little bowl, that fits over the nut head. I found them at one foreign auto parts place for $11.98 each, if it is the correct part. The auto parts workers can't verify it is the part I would like to purchase.           http://www.ebay.com/itm/Nardi-Steering-Wheel-Grommet-Fits-Nardi-Horn-Trim-Ring-/141153200210?pt=Motors_Car_Truck_Parts_Accessories&hash=item20dd62e852&vxp=mtr
michael romeo
1967  250sl
signal red
Louiehenry
« Reply #6 on: January 02, 2014, 18:49:18 »
I know they're rare and all but that seems rather steep... I bet nardi would have a few on their site?
