The loose wires under the hood do not have voltage when the green switch is turned on.......
David, Can you determine if the wires in front receive voltage from the switch on the dash? Seems easy enough. Just use a voltage tester on the wire(s) and flip the switch on the dash. If there is just one wire, that one should be the hot and you would use a body ground to check for voltage.
[/quote]
