Author Topic: Slave and Master Clutch Cylinder Rebuild  (Read 3385 times)
afisk
« on: January 11, 2014, 02:00:51 »
I have a '67 230SL. From the symptoms that I am experiencing with the clutch, I know that the cylinders need to be rebuilt. I am having a difficult time trying to locate the rebuild kit for the clutch's slave and master cylinder. Is there any place that I can find these rebuild kits?
Thanks in advance,
Aaron
George Des
Re: Slave and Master Clutch Cylinder Rebuild
« Reply #1 on: January 11, 2014, 02:58:40 »
I think it may be the wiser course to just buy new ones. The bores are probably scored and may leak withjust doing the seals. Replacements are no that expensive if you shop around.
