Author Topic: Adding Air Conditioning  (Read 9116 times)
DickLewis
« on: January 17, 2014, 01:14:11 »
Question.  I am restoring my 250SL which did not have a/c.  I am curious of the opinions of all of you about adding a/c.  The restoration is fairly high level but I am planning on driving the car and taking it to Mercedes Club events but I also want to add value in the long term which to me is 10 years.
Is adding a/c a good thing in the long run for re-sale or not?  It also looks like the newer units will be immediately noticeable to any judge or car enthisiast so what are your opinions please?
Thanks.
dpreston Virginia
  • USA, VA, Salem
Re: Adding Air Conditioning
« Reply #1 on: January 17, 2014, 01:36:11 »
Dick,
I added an aftermarket A/C to my 280SE Cabriolet and it makes the car so much more enjoyable. The A/C is identical to the one you can get at Buds.  I drive the car much more when I know I can turn on the cold air.
It could easily be removed, so I don't think it hurts the value of my car.
I will probally add the same A/C to my low mileage very original 280SL at some point in the future.
David
190SL 1960 Sold
280SL 1969
280SE 1969 cabriolet
Vette 67
Porsche 912 67
« Reply #2 on: January 19, 2014, 03:14:00 »
David, Where did you buy your kit from?
DavidBrough
« Reply #3 on: January 19, 2014, 10:49:44 »
I installed the Bud's kit in my car about 8 years ago and it works fine and could easily be removed if necessary
dpreston Virginia
  • USA, VA, Salem
« Reply #4 on: January 20, 2014, 02:00:54 »
I ordered it from the guy that makes them for Buds Benz.
He sold them him self for a while. I don't think he sells them direct now.
David
190SL 1960 Sold
280SL 1969
Vette 67
Porsche 912 67
Wayne
« Reply #5 on: January 29, 2014, 21:15:00 »
Im may buy a doner car to butcher for parts,it's a 280se and the car has original air con on it,will this fit to a pagoda with minimal alteration..or us it just a bad idea
I believe the cars share many parts,hence I'm buying for an engine
Both cars 1970
W
69280sl
  • USA, IL, Elk Grove
« Reply #6 on: January 30, 2014, 03:09:26 »
Wayne
Is the underdash portion of the 280se A/C identical to that of the sl?
Gus
Gus
George Des
« Reply #7 on: January 30, 2014, 13:56:03 »
Typically, the interior evaporator units on the sedans are much different from those used on the W113s. Some sedans used a Behr unit and some a Frigiking. All of the W113s I have seen with the dealer installed option used a Frigiking or Kuhlmeister evaporator unit that is essentially the same design. The underhood parts used in the sedan can be used on the W113 if the compressor is converted to a modern rotary unit like a Sanden. Do a search and you will find a post on this by Joe A. I've got the Sanden unit in my 230Sl with the Frigiking underdash unit. I did not use the sedan compressor bracket like Joe did instead using a bracket similar to the ones used with the Buds Benz unit, but may convert it over should I decide to keep the a/c unit in the car--I hardly use it anymore now I am in Florida and prefer to just go topless--I don't drive it around during the summer here since I'm usually up in Maine, so it is not a big issue
Wayne
« Reply #8 on: January 30, 2014, 20:26:12 »
Great thanks for your replies
I'll check out and if it can be used then I'll post on here
W
catjim813
« Reply #9 on: February 05, 2014, 22:16:46 »
Is there another supplier besides Buds Benz that has these kits that will fit the 113 cars?
