Alfred, just found your thread from October last year. Did you ever find a key code on the door handle anywhere?
Hello Jordan,
Well, I am not Alfred...
but nevertheless might be able to provide advice somehow.
Yes, the original doorhandles carry the stamped-in key code (something reading like "TA 042" or so) on the barrel that carries the door lock cylinder.
The picture shows a set of old door handles; on the right one you can detect the key code.
Replacement door handles have a small white sticker with the imprinted (new) key code.
If you don't find either of it you'll need a good locksmith.
But check your data card first. Have you still got your original door key (always starts with "T" for a 230 - early 280 SL)? Does it lock/unlock your passenger door? Yes?
Does it fit into the driver's door as well but just not turn?
For the latter case a locksmith can certainly help.
On the other side it is not uncommon that once in the past (only) your driver's side doorhandle was replaced.
Have you checked your second (= spare) set of keys? Probably the key you miss is there.
I have got three sets of keys with my car, all of them were incomplete.
But when I throwed them together I could eventually find at least one key for each of the locks, original & replaced.
So, some good research (homework) might help.
Good lock
(doorhandle collector)
