Author Topic: Tool - Remove Air Filter  (Read 5407 times)
dante53
« on: January 19, 2014, 11:25:57 »
What tools do you use to remove/reinstall BC or WRD air filter? I can't get enough room for ordinary wrenches (230 late IP).
« Last Edit: January 22, 2014, 09:36:05 by 280SL71 »
Jordan
  • Canada, ON, Jordan
Re: Tools
« Reply #1 on: January 19, 2014, 11:40:03 »
There are some wrenches you can purchase that are very narrow and will fit to remove the air filter.  I don't remember the size, 17 or 19mm, but I took an older wrench I had extra to a grinding wheel to make it narrower.  Worked out fine.
Marcus
66 230SL  Euro 4 speed
rogerh113
  • Los Altos, Ca
Re: Tools
« Reply #2 on: January 19, 2014, 16:28:35 »
Cycling wrenches are narrow and well built (and not particularly expensive).  They come in a variety of mm sizes, and I have used them for car repair in a number of cases like this (BMW fan clutch removal, for example) where spaces require a narrow tool.
Regards -- Roger
dante53
Re: Tools
« Reply #3 on: January 19, 2014, 22:32:11 »
Thanks for the hints. Tomorrow I will look for cycling wrenches. I know at least a couple of places where I should find a complete set.
Re: Tools
« Reply #4 on: January 19, 2014, 23:12:00 »
Dante,
Your W113 should be 19mm (3/4" can be used), latter W113s used 22mm (7/8" can be used).
rogerh113
  • Los Altos, Ca
Re: Tools
« Reply #5 on: January 20, 2014, 00:08:04 »
Didn't notice that you live in Italy......  Careful you don't return home with a nice bike along with the wrench !!
Ciao -- Roger
alchemist
  • USA, NY, GRAND ISLAND
Re: Tools
« Reply #6 on: January 20, 2014, 02:42:49 »
Mine uses 22 mm, I bought a regular wrench from Harbor Freight and grinded it until it became the same thickness as on the air filter nut. It worked fine.
rb6667
Re: Tools
« Reply #7 on: January 20, 2014, 21:00:25 »
Hello Dante, These pictures should give you some ideas on how to make your own wrench.  This wrench started life as a 14mm wrench.  After many trips to the bench grinder, it was opened up to 22mm.  Works great.
Check your progress often as you can't go back!
garymand
  • USA, CA, Meadow Vista
Re: Tools
« Reply #8 on: January 21, 2014, 21:08:10 »
Get used to modifying your tools to do the job.  I miss-place tools a lot so I typically have 2 to 4 of everything, so it doesn't hurt me to cut or grind one.  Have a container of water handy to cool it off.
Gary
69280sl
  • USA, IL, Elk Grove
Re: Tools
« Reply #9 on: January 21, 2014, 22:44:01 »
Grinding down an end wrench, which is what I did is a lot of unnecessary work. Buy a bicycle (what is called a cone wrench here in the US) wrench. Very economical and it works fine. Be sure it has a 19 mm opening.
Gus
Gus
Novamonte
Re: Tools
« Reply #10 on: January 22, 2014, 06:16:18 »
I rarely open my original MB toolkit, but the original wrench is actually narrow enough for this purpose. It is also short enough to remove the BC - standard wrenches tend to be too long to fit.
